I found this 170V'ish DC/DC smps and since I'm always looking for new ideas I decided to give it a try with LTspice. I have a 19VDC@3.2A Lap top adapter that would be a good start.
![]() I have a circuit that need 150VDC so it looks to be a match made in heaven. I read the text, looked through the schematics and did the sim. Either I'm missing something important or this is one faulty design? What do you think of it? http://greygum.net/sbench/sbench101/...plies/lvps.txt http://greygum.net/sbench/sbench101/...plies/lvps.gif In my sim: 1. The "power on" delay is necessary to start the oscillator but it's no delay? 2. No regulation until it hits the over voltage protection? 3. It's got almost twice the current draw compared to what's listed? |
#2 |
why don't you just use some IC?
#4 |
IC is more safe option, since it was design for that kinda operation... not saying that this above wouldn't work, but on the other hand...
I think I would use http://www.classiccmp.org/rtellason/chipdata/uc3844.pdf |
#5 |
It is a boost converter, I don't recommend that for so high convertion ratio. Try a transformr coupled converter, like pushpull or fullbridge.
#6 |
Using a boost converter with so high vout/vin conversion ratio is not recommended. On top of that
irf640 is a 200v mosfet and using it at vout=170v there is no safety margin. Maybe this circuit will work but it is much easier to use a controller like the uc3842 or similar. Instead of doing a boost converter make a simple flyback with properly desinged transformer turn ratio. If you don't need in/out isolation you can connect the transformer secondary gnd to the primary gnd simplifying also the feedback loop. A flyback converter is also inherently short circuit protected, a boost is not and can not be easily protected. Ciao -marco |
| Which 12V DC SMPS for amps? | tfboy | Class D | 20 | 9th August 2011 12:46 PM |
| to convert a 12v dc car adapter to support 19 volts dc | shadiedog87 | Power Supplies | 6 | 31st October 2007 07:27 PM |
| DC/DC 12V-15V inducterless Transformer Circuit needed | Tempest_au | Power Supplies | 6 | 22nd May 2007 12:37 PM |
| Combined PFC AC/DC & DC/DC SMPS | ChocoHolic | Power Supplies | 33 | 22nd December 2005 10:04 PM |
| DC-DC converter to get +-12V to feed the ouput opamps in DAC2000 | Ryssen | Digital Source | 12 | 22nd January 2004 05:04 PM |
| Page generated in 0.09276 seconds (80.22% PHP - 19.78% MySQL) with 10 queries |
