hi
can someone help me make an intelligent guess on how much current can this common mode choke passes? outer diameter is: 30mm height is: 20mm wire diameter is: 1.5mm i saw in ebay the one thats almost the same with this has 0.5mH 20A i wanna use this choke for less than 5A of +-35vdc. is this good for it? thanks in adv erwin |
#2 |
Looks like it will handle 5 amps no problem. Why do you want to use a common mode choke for DC?
#3 |
As a rough rule of thumb current density for wire in magnetic devices should not exceed 450 amps/cm^2. Using this your wire is good for 8 amps RMS.
Your core needs to be a low permeability core that will not saturate under DC current. |
#4 | |
Small magnetic components having a few turns in direct contact with the ambient air can tolerate current densities in excess of 8A/mm², so the 20 amp rating is probably realistic. |
#5 |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
As Elvee points out, saturation isn't an issue for CMCs because they're designed to run with very low net flux. The magnetization of the two windings cancels out leaving a very low differential-mode inductance and a much higher common-mode one. Saturation only becomes an issue if the two currents become unbalanced. Low permeability cores though are very useful for filtering out higher frequencies (say above a few MHz) where the higher mu cores give up.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen |
#6 |
thanks guys for all the replies.
i can conclude that i can use these choke for the 5A circuit. thanks jfitz57, i dont know to be honest. i saw few schematic using it and i would like to try it as it incur less losses in voltage. any insight? idea or suggestion? enlightenment? erwin |
#7 |
You use a common-mode choke when you have a common-mode noise/interference problem. Otherwise, you are simply adding some impedance (mainly winding resistance) to your PSU output impedance. Worth doing when necessary.
#8 |
Can one use this type of common mode choke in the CLC section of a linear +/- PS? They're so much cheaper and smaller than an air core inductor....
F.ex. D-K has a Triad Magnetics 2mH 7.5A CMC for under $5: 237-1230-ND |
#9 |
Not, a common mode choke is for choking common mode noise. It needs the two currents through it to be equal and opposite. It will not act as the L in a CLC filter.
#10 | |
| Common-mode choke discussion please | stellavox | Power Supplies | 8 | 25th July 2009 12:00 AM |
| Common mode choke model | eyalne | Tubes / Valves | 4 | 25th February 2008 10:22 AM |
| common mode choke question | schiller | Tubes / Valves | 4 | 13th February 2008 09:34 AM |
| isolation transformer as common mode choke? | av-trouvaille | Power Supplies | 3 | 4th July 2005 10:33 AM |
| Common mode filter choke... | JojoD818 | Solid State | 11 | 27th November 2003 01:59 PM |
| Page generated in 0.10792 seconds (80.86% PHP - 19.14% MySQL) with 11 queries |
