Hi All!
Im in abit of trouble. My transformers are very close to the output boards, and i fear trouble becouse of that. I do have both steel and cooper sheets that can be used to ehm.. screen(?) transformers from the outputs, but witch ones will be best to use? Sorry my bad english, not to sure about the words, hehe
#2 |
It has been my experience (from a grounding perspective) that stainless steel will ground RF better and copper will ground power better. In a shielding situation I think that the steel would be better since it is a ferrous metal. Lead would probably be ideal but the point is to prevent the magnetic lines of flux from messing with your output stages.
For this application I would go with steel. |
#3 |
A tin can (usually tin-plated steel actually) would also work here...
(konserv burk) |
#4 |
Okey, thank you both!
#5 |
Beware of inadvertently making a 'shorted turn' on the transformer when you bolt up any extra shielding.
| Tubes too close to output transformers? | dlec84 | Tubes / Valves | 8 | 18th March 2011 03:21 PM |
| tubelab simple se 6.3v close to output | pforeman | Tubelab | 3 | 8th August 2009 12:50 AM |
| 2 Transformers close together... | matic | Solid State | 4 | 7th December 2006 04:39 PM |
| CD player Drawer open close open close open close | qguy | Digital Source | 7 | 23rd November 2006 08:58 PM |
| Possible Interaction of Close Mounted Transformers | ppl | Solid State | 4 | 19th June 2001 09:15 AM |
| Page generated in 0.06150 seconds (83.83% PHP - 16.17% MySQL) with 10 queries |
