Hi All,
I am trying to design a simple shunt regulator to supply a small class a JFET preamp. It will be required to supply a maximum of about 15mA. I was intending to use a design similar to the one shown here in figure 3: Minimalist Discrete Hi-Fi Preamp I am interested to know if a fet or bipolar transistor (as shown) is better to use for this application? Which one has a lower ouput impedance? I have heard that the fet will make a more stable supply as the current draw through the zener will be more consistent if used in this circuit, but I suspect the bipolar version will have a lower output impedance. What are your thoughts? Your advice is appreciated. Greg, |
#2 |
It is true that the base current of a bipolar will vary according to the shunted current, but this variation can be made negligible by choosing a suitable B-E resistor.
On the other hand , a MOS has no gate current, but it does have a much lower transconductance, which means a poorer regulation, and variations in the zener current caused by the variations across the G-S resistor. |
#3 |
Ok thanks Elvee. I'll stick with the bipolar for this supply.
Greg. |
#4 |
At low voltages, as I presume this project is, bipolar is best.
Somewhere in the 50 to 100V range mosfets become better as high voltage bipolars have low Hfe and SOA limitations |
#5 |
I suggest to use this shunt regulator with bipolars, schematic and pcb is here:
A-class Preamp PSU Regards
http://www.facebook.com/APEXaudio.MileSlakovic |
| Placid-BP Bipolar Shunt Regulated Power Supply | Russ White | Twisted Pear | 170 | 13th January 2012 12:39 PM |
| Bipolar discrete shunt regulators | cetoole | Solid State | 589 | 24th August 2011 10:25 PM |
| CCS fed shunt regulators | mark_titano | Tubes / Valves | 3 | 30th May 2005 03:14 PM |
| Questions about shunt regulators | Bricolo | Parts | 5 | 16th September 2003 10:47 AM |
| LCAudio shunt regulators | OliverD | Digital Source | 4 | 16th December 2002 08:27 PM |
| Page generated in 0.07641 seconds (74.04% PHP - 25.96% MySQL) with 10 queries |
