Go Back   Home > Forums > Amplifiers > Power Supplies
Old 1st March 2013, 12:52 AM   #221
nigelwright7557's Avatar
I managed to get one of my pcbs working well at 5 amps and 25 to 35 volts output. Above 35 volts the regulation starts to drop out.
I built up another but with half as many windings on the transformer to see if I could get some more current. But I noticed in the spread sheet that I don't know how to fill in "Planned induction in core" which is in Tesla. How do I work that out ?
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software.
Old 1st March 2013, 10:48 PM   #222
The new pcb with less turns on the transformer was performing poorly with lots of ripple.
When I looked carefully I could see it was 100Hz ripple so my primary smoothing is inadequate.
Old 2nd March 2013, 01:17 AM   #223
Whoops the last time I blew the mosfets it also took out a pcb track near the smoothing capacitors.
I used my new isolation transformer to look at the primary side and there was no smoothing on the DC line at all, its amazing it was doing anything !
I am now getting +/- 40 volts DC at 5 amps.
Old 2nd March 2013, 11:05 PM   #224
I did some experimentation tonight with the control circuit resistors.
I found I could get a range of voltages out if I changed Rmax to a much lower value.
I can get from 25 volts to 40 volts out by using a preset on the secondary side to the tL431.
Old 3rd March 2013, 07:38 AM   #225
lorylaci's Avatar
Send a message via MSN to lorylaci
Decreasing the Rmax increases the maximal switching frequeny. If it is set too hugh, you will loose ZVS switching, and efficiency will fail.
Nigel. The LLC converter is intented to regualte the output at a certain value. This value is in the spreadsheet. It is NOT a PWM converter which you can use easily to set any output votlage you would like.
If you have an isolation transformer check the lower FET gate and the half bridge, as I said. If you psot soem waveforms I can easily tell it is ZVS or not.
Olyan nem volt még, hogy ne lett volna valahogy
Old 3rd March 2013, 03:37 PM   #226
My deadtime is around 1uS so I cant see the gate signal when the frequency is very high.
Here is a picture of lower gate and half bridge signal.
Old 4th March 2013, 02:52 AM   #227
I experimented a bit more tonight with varying the output voltage.
While I can vary the voltage a little the load also dictates what the output voltage range will be.
So keeping the output voltage set is the best way to go and just use the pot as a fine trimmer.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
