IRS27951 / IRS27952
IRS27951 / IRS27952
Old 30th December 2012, 07:10 AM   #11
lorylaci is offline lorylaci  Hungary
lorylaci's Avatar
Send a message via MSN to lorylaci
Nigel, I made multiple SMPSs with this IC. You can read about it
here on a Hungarian forum (translated to english with google for you)
I can help you, but I must ask some questions:
- could you draw the exact schematic you are using?
- what type of FETs are you using?
- you are balming things on satr ground etc... could you send a picture of your layout?
- What are you n and k values (turn ratio, ratio of magnetizing and leakage inductance)
- What type of transformer are you using? (core, gap, turns, wire)
I use a small aux baord for the controll, connecting in right next to the fets, this eliminates control common problems, however, this is a resonant converter and it is less sensitive to such problems then hard switching ones. So I think the problem is some other.
Olyan nem volt még, hogy ne lett volna valahogy
Old 30th December 2012, 02:29 PM   #12
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I have used the application note circuit.
I am using STP11NM60FD mosfets.
I am using an ET54 transformer with 36 primary turns and two 8 turn secondaries.
The aux transformer is 3 turns.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 30th December 2012, 02:42 PM   #13
[QUOTE=lorylaci;3303982- you are balming things on satr ground etc... could you send a picture of your layout?.[/QUOTE]
The star ground definitely made a difference although only running off 90 volts. The app note does mention using a star ground as being important.
Old 30th December 2012, 02:43 PM   #14
lorylaci's Avatar
You are missing the MOST important things:
What is the magnetizing and leakage inductance of your transformer?
Old 30th December 2012, 03:21 PM   #15
1.89 mH
I don't know how to calculate the leakage inductance.
I just wound on 36 turns on the primary and wound over the top two 8 turn secondaries.
Old 30th December 2012, 03:33 PM   #16
lorylaci's Avatar
1.89 mH
Then Nigel I am sorry to say that you have did not understand the concept of an LLC converter at all.
In shorts: the LLC acronim stand for: series inductance (leakage inductance), magnetizing inductance and resoannt capacitor.
These three reactive elements dictate two resoanant frequencies, which the conveter uses to stabilize the secondary voltage.
You must design THESE VALUES to fit your converter. Reread the whole application note!
Leakage inductance cannto be exactly calculated, it MUST BE MEASURED: measure the priamry inductance while SHORTING the secondaries.
Your converter fails to start, because of the low leakaage inductance: the resoanant current goes to infinite due to the secondary cpaacitors, causes a high votlage drop on the FETs which triggers the IRS275x overcurrent protection. This is exactly the cause of error. You simply did not read the application note.
Old 30th December 2012, 03:39 PM   #17
The inductance with secondaries shorted is 70uH.
I removed the secondary smoothing capacitors and the circuit runs so that confirms the 27951 is shutting down on over current.
I will read the app notes again.
I do have to admit I just took the app note circuit and scaled my transformer to fit my requirements.
Old 30th December 2012, 03:50 PM   #18
lorylaci's Avatar
70 uH could be a even good value depending on your projected frequency range. But your amgnetizing inductance is still large.
As you can see in the application note there is a value of "k" which is the ratio of the mangetizing inductance and the leakage inductance and is usually between 3 and 10 (while 1890 uh divided by 70 uH is 27).
Did you checked the hungarian link? You can find my schematic and my layout plan to, with pictures. You can see a picture of a completed converter too: you can see that the transformer uses a home-made split bobbin, and the use of the 3M yellow insulation tape.
Old 30th December 2012, 03:58 PM   #19
I didn't use a split bobbin, I just wound the secondaries on top of the primary.
I tried a gapped core to bring the inductance down to 550uH with a leakage inductance of 170uh but the circuit still wont power up. I just get a brief pulse on the output then the 27951 goes into power down mode.
The circuit runs fine on 90 volts DC but wont run on 320 volts DC.
Old 30th December 2012, 04:03 PM   #20
lorylaci's Avatar
You must use a split-bobbin, otherwise you won't get the sufficient leakage inductance.
Did you calculate your max current? What is the soft-start freqncuy?
With 70 uH and a 100kHz switching the current is about 6 A, which with the 0,4 Ohm mosfet will trigger the IRS27951 (2V max voltage drop on the FET).
You must calcuate the three tags and the frequencyies (and everything...). In the link you can find an excel spreadsheet, it follows throught the application note 8so you will figure it out, even if its in hungarian.
Its really helpful so try using it. Or I encourage you to make a similar spreadsheet according to the application yourself, it will help your design.
IRS27951 / IRS27952Hide this!Advertise here!
