IRS27951 / IRS27952
IRS27951 / IRS27952
Old 14th January 2013, 01:05 AM   #111
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Originally Posted by nigelwright7557 View Post
I looked at the power up pulse train and the 27951 is resetting well before the power up sequence ends.
If I remove the 470uf smoothing capacitors it powers up OK.
PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 14th January 2013, 05:11 AM   #112
lorylaci is offline lorylaci  Hungary
lorylaci's Avatar
Send a message via MSN to lorylaci
...Values...
It still overloads and stops.
Just to eliminate power up timer problems I used 47uF to stretch the power up delay.
But what is your soft start frequency? What is the soft start frequency setting resistor (Rss)? Without a resistor a soft start capacitor (Css) does nothing!
Olyan nem volt még, hogy ne lett volna valahogy
Old 14th January 2013, 02:05 PM   #113
Soft start frequency is 400KHz from 3k9 and 10uf.
Old 14th January 2013, 05:33 PM   #114
The circuit wont power up off mains but it does run on 90 volts DC.
I can see the high frequency power up sequence working then the frequency slowly drops to 25KHz. It is going to the lowest frequency as the 90 volts doesn't give enough voltage to make the opto-coupler output go low.
My problem is I don't have an isolation transformer to look at the primary side of the circuit.
Old 14th January 2013, 06:05 PM   #115
lorylaci's Avatar
I worked through the spreadsheet and input all my values:
Lm 800uH
Lr 85uH
Cr 100nf
k 7
If you have an Lm=800uH and a Lr=85uH, how can you have a K=7 ?
Your K is 9,4
(The spreadsheet uses function to calculate values. Cells with input are marked yellow. Don't write into cells with function)
From these values (k=9,4) i get a fmin of 33kHz. (19kHz will lead you to capacitive mode)
The primary peak current is 2,70A. This means you need a FET with Rdson < 0,74 Ohm, which is true for you. The IRS27951 starts with swtiching on the lower FET, and puts a bigger impulse out first.
What is your timing capacitor? 270pF?
Now its getting interesting...
If your Cr Lr, and freqs right, it should start up without a problem now.
Old 14th January 2013, 06:12 PM   #116
Sorry my Lm is 600uH and Lr is 85uH.
k = 7.
Timing capacitor is 390pf.
Old 14th January 2013, 06:27 PM   #117
lorylaci's Avatar
k = 7.
With 600uH - 85uH - 100nF combination the primary peak current is 3,6A. But it would also work with your 0,4Ohm FET (its on the limit but should).
Do you power with no load at output?
When you power up does the output voltage increase to some level?
Old 14th January 2013, 06:34 PM   #118
I have 660r across 45 to -45 volt lines.
I currently also just have 100uf per rail for smoothing.
I get a very brief but small voltage on the output.
The 27951 is resetting on the power up high frequency.
Its not getting a chance to get to the normal working frequency.
If I run off 90 volts I can see the power up frequency is fine and then it slowly settles down to about 21000Hz.
Old 14th January 2013, 07:04 PM   #119
lorylaci's Avatar
The IRS27951 first low output impulse has a double length (datasheet page 15). Do you use one 100nF capacitor, or 2x47nF split capacitor?
If you use a single, then at startup it has no voltage on it. And this (and the IRS27951 longer first impulse) causes a current transient, which triggers the OC of the IRS27951.
Old 14th January 2013, 07:15 PM   #120
I used a single 100nf 500 volt AC capacitor.
Do you mean put two 47nf in parallel ?
IRS27951 / IRS27952Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
