Hi, I would like to build a SMPS, but since I don´t have any EE or EI cores available, I was thinking about winding a transformer on a toroid core.
Is for example toroid T200-26 up to the task, and what power could I expect form such core say at 50kHz and 100kHz? How do you calculate/guess that? |
#2 | |
P=k*Ae^2*f (where if Ae is in cm^2 and f is in kHz, then k for half-bridge resonant is 4, for flyback its about 1) I don't really know this core, but you should look for its datasheet and calculate its losses at 100kHz. You should look for some ferrite-cores, they have much lower losses! (or try Vacuumschmelze: Home*-*VACUUMSCHMELZE GmbH & Co. KG You can order (buy) samples from them.
Olyan nem volt még, hogy ne lett volna valahogy |
#3 |
I hopefully found a source of Epcos ETD ferrtie cores, so the core should no longer be an issue.
Do you know some reliable SMPS schematic that I could use? I am planning for easily scalable 150-500W supply to power a bridged D-class single channel amp, so the output votlage will be in the order of 60V. Is it a good idea to implement PFC, or is that unnecesary? I was thinking of using a computer PSU schematic as a starting point, but am not sure if that is a good idea. |
| Flux Density in Car SMPS Toroid | Preamp | Power Supplies | 10 | 24th November 2010 01:32 AM |
| toroid for car amp smps | sss | Car Audio | 251 | 11th January 2009 02:55 PM |
| SMPS toroid transformer question | thoriated | Power Supplies | 11 | 6th April 2006 02:13 AM |
| toroid Transformer as output Transformer for tube preamp? | tone | Tubes / Valves | 15 | 2nd February 2003 04:36 AM |
| Page generated in 0.07373 seconds (71.88% PHP - 28.12% MySQL) with 10 queries |
