PSU  RC multistage filtering
Old 1st March 2011, 04:00 AM   #21
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Here are some results for a 4VA transformer with a 9V secondary when terminated with 47R and excited with 1VRMS.
DCR = 3.7ohms
50Hz = 8.0ohms
1kHz = 8.1ohms
10kHz = 16ohms
20kHz = 32.2ohms
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 1st March 2011, 06:17 AM   #22
gpapag is offline gpapag  Greece
gpapag's Avatar
Unfortunately I already have bought the caps based on my initial "dumb" sim, so will go ahead and build with 10,000 - 3r3 - 4,700 - 3r3 - 4,700... As I said an excercise in overkill!
Another observation I had when doing the sims (after realising the in-out difference needed to be 5V at least) was that it was better to have slightly lower resistance between the caps and higher ripple before the reg, if it meant that the pre-reg voltage was 5V or more higher, once the magic 5V was hit, any additional voltage (pre reg) made no difference... Of course this gets tricky as voltage drop increases as load current increases, so you need to choose the resistor values based on the max current draw expected.
Tony, what is your transformer's secondary and what is your intended load (voltage, min-max amperage)?
I may be able to set-up a mock-up of it, measure and see how it compares to your simulation results (in an attempt to fight the "overkill" approach).
George
["Second Law is a bitch." - SY]
["I insist on respecting the means of the average person working in their garage/basement." -Scott Wurcer]
Old 1st March 2011, 08:42 AM   #23
egberttheone is offline egberttheone  Netherlands
Send a message via MSN to egberttheone
First of all nice work.
You say you use wire-wound resistors, do you have a LCR meter to check the how much inductance these resistors have? This inductance could possible be helping to effectively smooth en the higher frequencies.
Old 1st March 2011, 10:26 AM   #24
DF96 is offline DF96  England
abraxalito:
Are you measuring resistance or total impedance (which includes leakage inductance)?
What do you mean by "proximity effect"? Do you mean mutual inductance i.e. transformer action?
egberttheone:
The inductance of a wire-wound is unlikely to be sufficient to make much difference within the audio range.
A general comment on regulators. These are essentially a servo system (i.e. using negative feedback), so like all such systems they need to reduce their HF open-loop gain to avoid instability. This means that regulation falls off at higher frequencies, and the output impedance may become reactive. This means that you can't necessarily simply slap a big capacitor on the output to compensate, as it might make things worse. The datasheet will give guidance. Also, their internal gain may depend on 'supply voltage' which could be the difference between input and output. This explains the better behaviour with a bigger voltage drop.
Old 1st March 2011, 11:03 AM   #25
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Hi George,
I've pretty much decided to build as is only components I haven't purchased are the transformer and the RC resistors. I don't have anything else to use the caps for so don't want to waste them
I can't find my notes, but from memory estimated current draw was about 160mA per rail (it will be a dual rail + 0 - supply) planned transformer is a dual secondary torroidal 15V 30VA (once again probably overkill but I wanted a safety margin). I'm allowing for 200mA / rail as a possibility and more if I should decide to go with a completely different approach should my active crossover circuit be a flop. I do plan on building this soon! Just have to stop procrastinating and order the last remaining bits.
DF96, I also wasn't sure about the 1000uF on the output of the reg in my circuit since 100uF is about the biggest you seen in examples in the datasheets, It was something that Fred DieckMann had recommended the circuit is based on his Idea (and also something I've seen a number of people say on various sites was a good value for LM317's (provided there is enough ESR, which I am adding in the form of a low value resistor). Certainly the datasheet doesn't mention any problem with larger valued caps.
Although the LM117 is stable with no output capacitors, like
any feedback circuit, certain values of external capacitance
can cause excessive ringing. This occurs with values between
500 pF and 5000 pF. A 1 μF solid tantalum (or 25 μF
aluminum electrolytic) on the output swamps this effect and
insures stability. Any increase of the load capacitance larger
than 10 μF will merely improve the loop stability and output
impedance.
I figured it works in the sim so should be ok... if not I'll drop it back to 100uF or so.
BTW the overkill doesn't stop there, but once I build everything, if it works I'll post it This is certainly a "project by a fanatic"
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 1st March 2011, 11:22 AM   #26
abraxalito's Avatar
Just the resistance. My meter separates out the leakage inductance (around 4mH I think it was) on another display.
No - the close relative of skin effect.
Proximity effect (electromagnetism) - Wikipedia, the free encyclopedia
Old 1st March 2011, 12:01 PM   #27
OK, I had forgotten about proximity effect (or I knew it by another name - can't remember now!).
It seems that some regulators are OK with big caps, but object to small ones. As always, read the datsheet and don't assume that other designers have done so.
Old 1st March 2011, 06:59 PM   #28
gpapag's Avatar
I measured 10 of them in series and divided the result by 10.
Then measured each one, and took the arithmetic mean .
Then added the result of these two operations and devided by 2.
The final value is L=12uH for each 4.7R/5W wire wound ceramic encapsulated resistor.
(Individual resistorís inductances measured from 9 to 17uH on the 200uH range of my LC meter)
On the internet, I didnít find any inductance value for such resistors.
So, I turned to the Ham world for coil calculations.
This site has more than I would like to know.
RF Inductance Calculator - HAMwaves.com
I broke the ceramic housing and measured the dimentions of one of the coiled resistors:
Coilís Diameter: 3.7mm
Coilís Length: 7.0mm
Wireís diameter: 0.02mm
Number of turns: 12
Calculated L=0.3uH due to geometry, independent of frequency.
The frequency dependent Inductance is up to 500MHz another 0.3uH, so the total calculated L= 0.6uH.
Why such a big difference btn measured and calculated?
Probably due to the end cups and leads which are magnetic?
So, taking the highest inductance of the two (L=12uH) what can the HF roll-off be?
Here I give up.
Pi sections, T sections and the like, anyone?
George
Old 1st March 2011, 07:07 PM   #29
gpapag's Avatar
Hi George,
Tony, I would place one of the largest capacitors just before the voltage regulator.
At least consider to leave enough space there for the big one to experiment with this later.
George
Old 1st March 2011, 07:23 PM   #30
just another
wintermute's Avatar
I've read it (actually TI's Natsemi's and LT's) multiple times another thing which is not applicable to the 7818 but is a very important hint in the LM317A Data Sheet is that the top resistor in the resistive divider should be connected directly to the case of the regulator, NOT to the load, and the bottom resistor in the resistive divider should be connected with as low a resistance connection as possible directly to the load. Another example of why you SHOULD read the datasheet! You won't pick that up from any schematic In this case mutiple datasheets because they have subtly different information in them. first is from Natsemi, second from Linear Technology.
Tony.
Some of my photos
PSU  RC multistage filteringHide this!Advertise here!
Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted tiefbassuebertr Multi-Way 2 20th September 2010 11:20 AM
RE: RC-19 or RC-30 chungtat Tubes / Valves 6 6th August 2005 03:51 AM
'Local Feedback and Nonlinearity of Multistage Feedback Amplifiers' mikeks Solid State 62 20th July 2005 08:03 AM
filtering switched mode PSU for SI 5066 amp supply jives11 Parts 0 24th January 2005 09:19 PM
