Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th February 2011, 02:32 PM   #1
Question Antek
So i recieved my Antek AS-4225 yesterday in the mail!
And on the label, it shows a purple wire as a 'static shield'
What do i use this for?? more so, since its pretty self explanitory, where do i hook it up in this whole amplifier system??
Old 26th February 2011, 03:33 AM   #2
Einric is offline Einric  United States
From what I would understand ( I am looking at an AS-3225 ) the static shield would go to ground. The primary and secondary windings should be varnished and safe. Grounding the shield would dissipate any noise between the primaries and secondaries.
Old 27th February 2011, 07:38 AM   #3
silverprl1's Avatar
Be careful of the HOT GROUND is MOST SMPS.... DANGEROUS
Old 27th February 2011, 10:15 AM   #4
posts 1 & 2 are both referring to an Antek supplied transformer.
Where did smps come from?
regards Andrew T.
Old 27th February 2011, 12:07 PM   #5
silverprl1's Avatar
My bad - clicked wrong link -
Old 27th February 2011, 03:43 PM   #6
Perfect! Thank you guys very much! And the ground will soak it all up and I wont have any of it trying to go back into the circuit?
Old 9th March 2011, 04:22 AM   #7
Any noise dissipated from the shield and static shield would seek the shortest path to ground. This would be the third prong on the NEMA plug (ground) and it would head out to the building/panel ground from there.
Old 9th March 2011, 02:33 PM   #8
exactly th answer i was looking for!
Antek toroidal vs Edcor? Divad89 Tubes / Valves 12 9th February 2011 07:44 PM
More Antek Iron rknize Tubes / Valves 14 22nd January 2011 12:10 AM
Antek OPT mr2racer Tubes / Valves 27 9th September 2010 12:07 PM
Antek Toroid commoncollector Chip Amps 0 9th December 2009 06:03 PM
AnTek vs. Plitron Colescuttle Parts 1 10th March 2009 04:55 AM
Page generated in 0.07061 seconds (83.75% PHP - 16.25% MySQL) with 10 queries
