Go Back   Home > Forums > Amplifiers > Power Supplies
Old 22nd February 2011, 12:19 AM   #1
Default Thermocouple meter, measuring MOSFET temperatures
What's everyone using for measuring the temps of their SMPS components?
I bought a cheap thermocouple meter from China and almost fell off my chair when the temperature of my MOSFET tab appeared to go from 20 to 100 Deg C in 1 second with heatsink attached. Of course this higher unlikely so it appears as though the meter is very susceptible to EMI.
My meter is a dual channel but the K type thermocouples aren't electrically isolated so no simultaneous measurements of the HS and LS MOSFETS.
I want to buy a better meter but I don't know what meters are not influenced by EMI and electrically isolated between channels. Any suggestions are appreciated!
Old 22nd February 2011, 08:49 PM   #2
mag is offline mag  Switzerland
Hi leadcoma,
isolate all your thermocouples with a thin film of adhesive kapton tape to avoid insulation problems. In this case you can measure at the same time all the temperatures you want.
If you put the thermocouple directly on the mosfet tab without insulation it is very likely to occur noise pickup that disturbs the measure.
Don't rely on the insulation between the channels of the instrument.
If noise is still picked up with insulated thermocouples you can simpliy heat up your smps with all the thermocouples in place and then switch it off to take the temperature measurement. Temperature shuould not change significantly in a second or two, especially if your mosfets are attached to an heatsink.
Ciao
-marco
Old 22nd February 2011, 09:25 PM   #3
I bought an EXTECH Easyview 11A meter which is a single channel meter. Works great and I have had no problems with funny readings as I do with the 15 dollar Chinkanese meter I originally bought.
Extech also make a dual channel meter and I should of gotten that one instead, oh well.
Old 22nd February 2011, 11:18 PM   #4
nigelwright7557's Avatar
I use a handheld infra red thermometer.
Works very well and was about £20.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 23rd February 2011, 01:56 PM   #5
thanks for your responses
Marco, good tip, looks like that works
Nigel, I too have an IR type but mine can't differentiate between the heatsink and MOSFET tab
Old 23rd February 2011, 02:52 PM   #6
Originally Posted by mag View Post
Temperature should not change significantly in a second or two, especially if your mosfets are attached to an heatsink.
some of the thermal time constants are in the tens of milliseconds.
regards Andrew T.
A LED meter, Volt meter, power meter or light indicator... a nice gadget destroyer X Solid State 5 25th February 2011 06:30 PM
Measuring milliamp with Fluke 771 Clamp Meter Question? manp111 Tubes / Valves 14 31st December 2010 08:07 AM
Could anyone lend me his/her ESR/ESL meter for measuring Pana FC/FM/TSUP caps? antomas Parts 1 4th January 2007 05:29 PM
Measuring current with an LCD meter Matttcattt Parts 10 12th May 2004 12:13 AM
Thermocouple calibrators - what's inside? peranders Everything Else 15 5th June 2003 06:19 PM
Page generated in 0.08494 seconds (82.68% PHP - 17.32% MySQL) with 10 queries
