Go Back   Home > Forums > Amplifiers > Power Supplies
Old 14th December 2012, 03:36 PM   #31
vasko is offline vasko  Czech Republic
So I'll just use TL494 in push pull mode with two FETs with UF4007 and RC circuit. That will bypass flyback issues? And I'll use DTC to drive lamp without ballast cap/inductance.
Old 14th December 2012, 04:26 PM   #32
Hi
You can't do a push pull without a dual winding transformer. You'll have to wind one yourself, or use Class C with a (tuned) pulse drive. Normally lamps will need a ballast to run or they present a short circuited laod (or low impedance at any rate) which will ruin the resonant circuit, but this would normally be needed for any tube driver.
You can only set the inductance once you know the frequency your converter runs at, and the leakage inductance of your LOPT etc.
Many cheap circuits on the market do just what you suggested originally and run the tube from a pulse transformer, but the lamps don't last long - this is the point.
Cheers
John
Old 14th December 2012, 06:20 PM   #33
Originally Posted by john_ellis View Post
Hi
Offcourse I'll make dual primary winding for push pull, that's implies.
Elevam's oversized Neon Lamp for Micro Seiki 5 - where to order tiefbassuebertr Analogue Source 10 5th June 2012 02:23 PM
Wiring SPST Switch with Neon Lamp PhrazeMaster Construction Tips 5 9th January 2011 08:28 PM
Neon Power? Trout Tubes / Valves 12 29th April 2006 06:03 AM
Where can I get a neon lamp for Garrard 401? honinbou Analogue Source 12 10th March 2006 06:56 PM
neon lights Jordo Car Audio 1 21st November 2005 05:24 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
