Go Back   Home > Forums > Amplifiers > Power Supplies
Old 15th February 2011, 12:50 AM   #1
cobretti's Avatar
Default Help with bypass CAPS
What's the rule of sizing the bypass CAPS in rectifier bridge? I am using this power supply, originally designed with 4x100nF caps in the bridge. Since I am using 120V transformer instead of 220V, what should I do with these caps? I assume that these caps are supposed to help to filter the incoming power. I was reading that improper value of these 4 CAPS can make a lot of problems, make the power worse than not using them at all. Any help appreciated.
Old 15th February 2011, 11:27 AM   #2
mastodon's Avatar
Here you go: http://www.hagtech.com/pdf/snubber.pdf
In laymen's terms (correct me if I'm wrong): the diodes cause brief spikes when switching and the snubber caps are intended to suppress those spikes and prevent them from being superimposed on your filtered DC.
No change needed; the secondary voltage doesn't change compared to the schematic you included; it's only the primary. The same snubbers can be used.
Old 15th February 2011, 07:31 PM   #3
cobretti's Avatar
Many thanks. Tha't exacly what I meant. I did't realize that the secondary voltage is staying the same, indeed. No help needed then.. Yes, snubbers, I have seen some people talking about it already but had no clue it's this. Thank you.
Old 17th February 2011, 01:16 AM   #4
cobretti's Avatar
Another, more important thing I forgot to ask. It's the frequency change from 100Hz to 120Hz. Any guidelines on this? thanx
4 pole caps and bypass caps BigE Power Supplies 9 14th January 2011 01:39 PM
Best Bypass Caps? Ben Reginato Multi-Way 1 2nd March 2008 01:58 PM
bypass caps for bypassing mylar caps? crippledchicken Multi-Way 4 27th February 2008 04:24 AM
Bypass caps on crossover caps... :D quickshift Multi-Way 19 27th November 2005 12:59 PM
Bypass caps Praise! Parts 1 9th April 2004 01:28 AM
Page generated in 0.08390 seconds (73.82% PHP - 26.18% MySQL) with 11 queries
