Go Back   Home > Forums > Amplifiers > Power Supplies
Old 14th February 2011, 11:04 PM   #1
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
Default looking for simple voltage doubler
to double 12V to approx 24V .18V is also ok , so no need for regulation and very low current will be good also.
i'm looking to do that with low parts count and cant find any ic that will do this simple task.
most charge pump ic's does not include the diodes for voltage doubler , and they work only for low voltage (around 3-6V)
any ideas?
thanks guys .
if you are not living on the edge you are taking too much space
Old 14th February 2011, 11:23 PM   #2
Banned
MAX1044 will double or triple 9V. 10V max, so you will need to regulate down.
w
Old 15th February 2011, 02:22 AM   #3
jcx is online now jcx  United States
the ICL7660 works from 12 V, needs diodes for positive doubling
Old 15th February 2011, 03:39 AM   #4
jfitz57 is offline jfitz57  United States
LM386, couple 1N4148's, resistors and capacitors... RadioShack stuff...
Old 15th February 2011, 12:48 PM   #5
sss's Avatar
i was hoping that there is some ic that includes the diodes and all i need is external caps.
anyway ,i guess that 555timer is the cheapest solution and almost the same parts count.
Old 15th February 2011, 02:45 PM   #6
really low current - a few 10 uA can be had from SS relay mosfet gate driver PV diode stack optoisolators - insanely low efficiency too
Voltage doubler questions db! Power Supplies 10 7th November 2010 12:30 PM
Need help with voltage doubler Lingwendil Power Supplies 6 22nd April 2009 12:15 AM
Voltage Doubler jwatts Tubes / Valves 3 2nd January 2009 12:13 AM
Voltage doubler Baard Solid State 28 17th January 2005 04:46 AM
Voltage Doubler Problem runeight Tubes / Valves 10 7th April 2004 04:16 AM
Page generated in 0.08506 seconds (70.55% PHP - 29.45% MySQL) with 10 queries
