i'm trying to make my first SMPS inverter and i need some help. the inverter makes +-24Volt supply out of 12 volts. i calculated that if i use a Dout=30mm, Din=20mm, h=10mm toroid, i'dd have to make 2X4 turns primary and 2X11 turns secondary. i use SG2525A for the controller @ around 70kHz. i use total of 4 IRF1010N and 4 FES16DT for the diodes. it should power 4 channels with 70-75 W rms @ 4 ohms or 2 channels with ~250 W rms @ 4 ohms. will 8 amp rating be enough for the trafo4? now i haven't wound any toroids before and i need help. i think it might look something like this: ![]() how wrong am i? any tips? is 0.5mm wire ok for the task?(in bundles) thats for 8 amps and it makes 8 wires for the primary windings and 5 wires for the secondary... does any of it make sense? Thanks! |
#2 | |
Next you are talking about 240W of power I just don't see that happinging with a small transformers like this. What is the core material? |
#3 |
here are the schematics. car amp inverter trafo
its a class D car amp. i haven't figured out the core material yet. Last edited by openport; 14th February 2011 at 10:46 PM. |
#4 |
Schematics don't show up in the thread you linked to...
#5 |
sorry.
here are the schematics. http://imageupload.org/?di=812977785457 http://imageupload.org/?di=1012977785473 http://imageupload.org/?di=1012977785472 Thanks. |
#6 |
both primary should be BIFILAR and cover whole CIRCUMFERENCE of the core
#7 |
does anybody know a tutorial or something?
i have searched the internet for a week now. and i can't find a decent tutorial on small core trafos. they all show how to make one if you use the grid. i use a battery. how should the trafo look like if i use Bifilar winding so one primary should cover half of the core |
#8 |
Did it Himself
Bifilar means take two wires together and wind together. You should always evenly cover the way round the toroid, especially when there is just a few turns.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#9 |
i mean how do i have to wind it if i have to use 8 wires?
just like 4 bifilar coils side by side? |
#10 |
u can do some experiment on various bifilar winding techniques and let us know the results, some twist both the primary and wind, others lay the wires side by side(pri 1 - pri 2 - pri 1.......), some even go a bit farther and twist the primary and secondary together, all these techniques has deferent pros and cons, if i am building a 12v to 24v dc/dc and dont need tight voltage regulation then, i would try to twist all the primary and secondary together and wind and see what happen.
| Wind my own output transformer for 100w bass amp | audiojerk | Tubes / Valves | 18 | 16th May 2008 02:35 PM |
| How to wind a Car AUdio SMPS Transformer | thefish | Parts | 10 | 3rd November 2006 04:14 AM |
| How to wind a transformer | MaXiZ | Solid State | 13 | 8th December 2003 12:07 AM |
| How to wind a transformer for multiple output? | MaXiZ | Pass Labs | 1 | 1st November 2003 04:38 PM |
| toroid Transformer as output Transformer for tube preamp? | tone | Tubes / Valves | 15 | 2nd February 2003 04:36 AM |
| Page generated in 0.10005 seconds (79.33% PHP - 20.67% MySQL) with 10 queries |
