Hey guys
Starting a Thread to finish up a PS for the KO amp development. First out of the box... The transformer needs to have clarification, as to what each lead does. This is an older transformer out of a receiver. Any ideas? as to the color code of the leads OR how to go about systematically testing to determine which lead is What... ![]() There are two 2 blue 2 red 2 orange 2 green 2 white 2 brown the blue pair and one brown and one white come out of one side the rest come out the other it is potted and I believe it is a toroidal
Thanks ![]() Never give a Systems Analyst a screwdriver or hammer
#2 |
ok
the 2 reds and the white on the output side form a circuit, the white is the center tap the 2 orange and the 2 greens form a similar center tap with the brown as center the blues have about 400 u ohms across them the brown and white on the input side have about 900 u ohms I found the manufacturer in Malaysia, emailed and asked them for specs, it is an old Japan-Malaysia company. They say that they make 150000 transformers a month for audio nice looking stuff. Company name is Bando. I am almost sure that the input side is set up for 110 / 220 I have to figure it out. I am going to put the pictured display on the final unit... IF I can get it up and running. The caps that were in the circuit are 22,000 at 71 volts..So I am hoping for something near that
#3 |
hey that looks good
next, glcd and plote the past voltages, as they sag
#4 | |
![]() I will save the fancy stuff for later...
#5 |
there could be a faster way...flowcode
I bet it would be very easy and how awsome would that look
#6 | |
#7 |
well it is graphical programing, pic or avr or arm
![]() This is how it looks... and what you have, is glcd also now, I will have to say, that apart from bolks they sell with this type of lcd, I'm not sure what kind would be needed But other things like ADC, interrupt, 2x 16 or other lcds, pwm, stepper motor, 7 segment and so on is ultra easy really fun way to program |
#8 |
Luka:
Does this system work with Arduino? I have programed in about 11 different languages from GWBasic to AutoLisp but I have never seen anything like that... ![]() Here is the box I am working on, I will put in the above pictured Transformer IF I can get it to work and understand the specs of it. And MAYBE stick the display in if time permits... I have to open it up a little and Wire and Wire it UP...I hate construction of boxes like this, but I had to put together SOMETHING fast, not my best BUT functional to say the least. ![]() I am open for suggestion from any and all sources, tell me quick before I start wiring this beast.
#9 | |
Do you have any external program for flashing avr? like I have pickit, and I can upload any code as long as it is hex and all that. What is full ic ID that is on board? ATmega328?
You can program any of below avr's Quote:
#10 |
Here is the easy way for the AC Display for less than 10 bucks, but it needs a power supply ( which could be a wall transformer type) to run...
![]() I can tie it to the output of the Variac.... I am going to finish this box up and get it on the air. ![]() I have got to stuff and test some amp boards, but all of this was dependent on have some form of testing power supply. I will start off with about plus and minus 10 to 15 volts.
| PS Audio PS Elite Integrate Amp | jimmy50 | Solid State | 14 | 5th May 2012 06:07 PM |
| PS Audio 200C Power Amplifier | kkyee | Solid State | 4 | 12th November 2008 06:47 AM |
| Anybody make a PS Audio Power Conditioner clone? | ozone_stink | Everything Else | 1 | 18th November 2005 04:03 AM |
| How do diy PS audio power plant and Power Director 4.7? | bmpa | Parts | 2 | 6th May 2004 05:58 AM |
| PS Audio Power Director experiences/opinions? | dc | Everything Else | 0 | 8th July 2002 06:00 PM |
| Page generated in 0.12464 seconds (82.61% PHP - 17.39% MySQL) with 11 queries |
