I have a really big 50 - 0 - 50 trafo here with me, but i need +-70 for 2x400w amp...
can I use this trafo for +-70 like in this circuit ? ![]() sorry for my poor english, i'm brazillian Last edited by dougfunnyBR; 12th February 2011 at 03:05 PM. |
#2 |
#3 |
Yes you can use it. If you look at the picture you can see they used the same trafo as you've mentioned.
#4 |
yeah, but can i use for 2x +-70 ??
#5 |
#6 |
just another
The magic number is 1.414. multiply the secondary voltage of the transformer by that and you will get "roughly" the rectified voltage. 50V is the RMS (root mean square) voltage of the transformer, the peak to peak voltage will be 70V.
Note that there are other influences as well. There will actually be a small voltage drop due to the diodes, and when not under full load (depending on transformer regulation) the voltage could be a bit higher. check out this article by rod elliot for a better understanding Elliott Sound Products - Linear Power Supply DesignTony. |
#7 |
that circuit makes much more sense now..
thanks for all guys ! diy is awesome !! |
#8 |
A 230:50Vac transformer will over voltage 75Vdc smoothing caps in worst case operational conditions.
regards Andrew T. |
| Power trafo... | Psychobiker | Tubes / Valves | 4 | 25th October 2007 07:52 AM |
| Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? | rhythmdiy | Chip Amps | 9 | 23rd October 2007 12:30 AM |
| Help with trafo | Hojvaelde | Tubes / Valves | 1 | 13th February 2006 08:12 PM |
| Of what value is this trafo? | wxn | Parts | 7 | 13th June 2005 12:08 PM |
| trafo.. | samsagaz | Chip Amps | 16 | 31st August 2004 02:17 PM |
| Page generated in 0.10587 seconds (72.21% PHP - 27.79% MySQL) with 10 queries |
