hi guys
i am confuse about the term isolation transformer. is transformer with primary winding and secondary winding is regarded as isolation transformer? say normal audio transformer of 0v-15v on its secondary. is this consider as isolation transformer as well which is only output 15v instead of normal 110v or 220v? or isolation transfomer is something else that not just primary and secondary winding thanks erwin |
#2 |
The usual meaning of an isolation transformer is a 1:1 ratio to supply the same voltage as the primary such that there is no galvanic connection between the source and load.
And yes, all transformers isolate but aren't called isolation transformers. |
#3 |
thanks bob for the confirmation. i am clear now.
erwin |
#4 |
for mains use, isolation transformers are tested to very high isolation voltages. I think 1500Vac for a few seconds. I doubt an ordinary audio transformer would meet this safety standard. They normally only handle a few volts or at most a few tens of volts. The output transformer of a valve/tube amplifier may be safety tested to a similar standard as a mains isolation transformer.
regards Andrew T. |
#5 |
Just to add that "auto transformers" and Variacs provide no isolation between input and output yet come in the category "transformers".
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#6 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
A further clarification....True isolation transformers have whats called a split bobbin. The bobbin is the plastic core onto which the primaries and secondaries are wound onto. The "standard" bobbin has both primaries AND secondaries wound on top of each other in an interleaving pattern. The isolating value being the 'tape' that separates each stack of windings. The split bobbin has a large ( 3 mm?) wall of plastic, a barrier that separates both windings. The split bobbin is less efficient but has superior isolating properties.
__________________________________________________ __Rick.......... |
| Using primary as the secondary winding in the power transformer. | mishak | Parts | 10 | 30th May 2010 05:55 AM |
| safest way to identify primary/secondary? | gary h | Power Supplies | 15 | 6th January 2010 03:56 PM |
| cap btween primary and secondary windings? | sam9 | Power Supplies | 8 | 19th May 2005 06:34 PM |
| Why a Zobel network across OPT primary or secondary? | ray_moth | Tubes / Valves | 6 | 4th March 2005 10:26 PM |
| Using the secondary of a normal transformer as the primary to get a HT supply | baggystevo82 | Parts | 9 | 2nd April 2004 11:02 PM |
| Page generated in 0.08243 seconds (75.03% PHP - 24.97% MySQL) with 10 queries |
