need advice on fuse value and rectifier
Old 2nd February 2011, 06:18 PM   #11
fhs is offline fhs  Germany
fhs's Avatar
Hi Erwin,
my only reason for using an NTC is to limit the inrush current so that I can use an appropriately rated fuse. Again, you can use a resistor to perfom the same function. Either one should be short-circuited by a relay after a little while.
Slow-start circuits are a different ball of wax: I do use them for my DC filament power supplies, hopefully increasing tube lifetime. I also delay the application of HV to the tubes. In your initial question, you mentioned a 50000 F capacitor -- it's obvious that we are not talking tubes here. I do not have any experience with solid-state amps and vacate the turf for people more knowledgeable than me. I cannot really comment on the effect of slow-start circuits on solid-state audio equipment.
All the best,
Fred
Old 3rd February 2011, 09:29 AM   #12
Originally Posted by AndrewT View Post
The fuse for 220Vac supply is 3 * 75 / 220
Originally Posted by fhs View Post
No (not considering the <1 efficiency of your transformer): 75W at 230V = 75/230A <0.5A; 75W at 115V = 75/115A < 0.7A. OK, you have some leeway here and may use a fuse with a somewhat higher rating.
the formula has nothing to do with efficiency.
It's standard for transformers and motors.
You state "somewhat higher rating".
That "somewhat" equals 3.
As I went on to say, if you want instead to use close rating then a soft start of some type must be used to allow the lower fuse rating to survive repeated start ups.
regards Andrew T.
need advice on fuse value and rectifierHide this!Advertise here!
simple se blowing rectifier and fuse newtube Tubelab 15 16th May 2009 11:54 PM
Fuse housing melting but fuse not blowing, ppi amp rawadia Car Audio 21 2nd August 2008 11:39 AM
Why main fuse and not rail fuse? digital desire Solid State 10 3rd December 2006 09:07 PM
amp rating for fuse and fuse holder? riotubes Parts 5 27th August 2006 04:10 AM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 05:02 AM
