Can someone please suggest +/-18V regulator for phono preamp?
I would go with the Jung/Diden super regulator but it seems that opamps can't handle that much voltage.
#2 |
Use a Salas type Shunt regulator.
There are many threads extolling the sound quality that results from adopting the Salas.
regards Andrew T. |
#3 |
There's no problem at all using a Jung SR at those voltages - you need one for +ve which is supplied from+ve raw supply to 0v, and one for negative, supplied from -0v raw to 0v. With only minor care (such as watching disspation in parts and heatsinking) you can use Jung superregs to supply well over +/-30v.
Take the time to read the documentation on Walt Jung's homepage: Walt Jung - Regulators - there is much pertinent information given, whichever route you choose. Last edited by martin clark; 30th January 2011 at 06:37 PM. |
#4 |
Yes, I have read some of the articles, and considered mounting the heatsinks on the opamp, but the 18V output seemed to much of a stretch for the AD817. I thougt that the regulator will loose some of the good characteristics that way.
I will try the Super Regulator then (since I've done them before), but now I'm intrigued with the Salas. Thanks! Last edited by arlekin; 30th January 2011 at 11:05 PM. |
| Erno 320 jfet phono DC offset drifting between +0.2V and -0.18V | Sunsun22 | Solid State | 4 | 30th September 2010 03:53 AM |
| FS: (2) 18v+18v 400VA Antek Toroid Transformers | mezz64 | Swap Meet | 3 | 5th May 2010 05:10 PM |
| Lithos regulator - A new super regulator? | peranders | Parts | 7 | 8th May 2008 02:01 PM |
| Super fast, low noise phono preamp | dioklecijan | Analogue Source | 30 | 19th July 2004 09:52 PM |
| Page generated in 0.07463 seconds (71.85% PHP - 28.15% MySQL) with 10 queries |
