Can a Filtered IEC Power Inlet Improve Sound Quality?
Old 29th January 2011, 09:38 PM   #1
Haz is offline Haz  United Kingdom
Default Can a Filtered IEC Power Inlet Improve Sound Quality?
Just a quick question does a filtered IEC power inlet improve sound quality, When using a switching power supply?
Or should just use a normal IEC and not bother with one? If any people have any advice about these that would be much appreciated.
Schaffner FN388-6 IEC 6A Inlet Filter, Fused/Switched on eBay (end time 30-Jan-11 08:41:41 GMT)
Thank you
Old 29th January 2011, 10:07 PM   #2
phaselag is offline phaselag  United States
It can if you click your heels 3 times and say "I Believe"
paul
Old 29th January 2011, 10:07 PM   #3
bob91343 is offline bob91343  United States
The filter does not affect performance. It's there for a few reasons, most of which have to do with EMI and FCC regulations. Noise generated within the unit needs to be attenuated before exiting the power cord; noise on the power line needs to be reduced (in rare cases) before entering the device.
If you are building something or using a commercial unit, don't worry about it unless you have a specific problem that can be traced to EMI.
Old 29th January 2011, 10:13 PM   #4
Thanks for the information, I was just curious about them after seeing this listing on ebay.
NEW MAINS CONDITIONER WITH FURUTECH AC-1501 IEC FILTER on eBay (end time 17-Feb-11 16:45:48 GMT)
I know you should not believe everything you read that's why I ask.
Old 30th January 2011, 06:29 AM   #5
AEIOU is offline AEIOU  United States
AEIOU's Avatar
Send a message via AIM to AEIOU Send a message via MSN to AEIOU Send a message via Yahoo to AEIOU
Did you read this article posted here at DIYaudio?
Audio Component Grounding and Interconnection
Scroll down a bit and it reads "Include a line filter on equipment that you build."
Old 30th January 2011, 10:11 AM   #6
The filter between the mains supply and the equipment works both ways.
If you have quiet equipment and want a quiet supply, the filter attenuates the incoming Garbage coming from the mains.
If you have noisy equipment and want a quiet supply for the rest of the house, then the filter attenuates the Garbage that the noisy equipment tries to send back through the mains cable.
regards Andrew T.
Old 30th January 2011, 02:36 PM   #7
DF96 is offline DF96  England
Yes, when using an SMPS you really need a filter to stop it exporting noise around the house and to your neighbours. Part of being a good citizen!
Old 30th January 2011, 02:44 PM   #8
On Hiatus
SY's Avatar
Especially when it's written that ungrammatically and contains idiocies like this:
The effect of a cleaner mains supply is better sound and picture quality if used with TV's, quieter backgrounds in music and movies and an overall improvement in bass, mid-range and treble, proven by customer feedback and repeat purchases. The conditioner is terminated with a silver plated kaiser IEC connector and utilizes Black Rhodium fusion silver plated mains cable (which has won awards for it's outstanding performance).
No better specification for the money on e-bay, 2000+ positive feed backs means happy customers.
AC-1501 IEC inlet with EMI filter 24k gold plated. (Alpha) non-magnetic copper alloy conductors. Outer cover chrome plated steel plate, Inner cover Nylon glass fibre, Inner parts held by Piezo Epoxy Rating:115V/250V 15A 50/60Hz
...and is accompanied by a price that is approximately ten times what normal, identically-functioning units cost. Must be that piezo epoxy. Or the award-winning Black Rhodium fusion silver plating.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 30th January 2011, 04:10 PM   #9
Of course, normal cheap IEC filters use magnetic copper!! And you need chrome plating on something which will be hidden inside a unit - you can't see it, but knowing it is there enhances the warm glow on your face and the placebo effect in your ears.
Old 30th January 2011, 06:24 PM   #10
aandy is offline aandy  United Kingdom
if you can find them the blue IEC inlets sound better
Can a Filtered IEC Power Inlet Improve Sound Quality?Hide this!Advertise here!
Wiring an IEC inlet mourip Parts 5 31st January 2013 06:02 PM
What do you think about filtered IEC inlet? rg12 Parts 4 15th August 2010 09:59 PM
IEC Inlet Filter confusion jkeny Power Supplies 0 31st July 2008 09:17 PM
Construction: The best way to cut a hole for an IEC power inlet into sheet metal PaulHilgeman Parts 10 16th October 2003 08:36 PM
Copyright ©1999-2017 diyAudio
