I have a problem. I can get cheap 2*30V torroids, but the output voltage is too high for my purpose, supplying a LM4780. I would like to get the voltage within the specs of the LM4780, say, between 30 en 35 Volts. What is the best way to do this and what is the easiest/cheapest way to do this?
LM317HV with transistors 5reg.gif (image) LM338HV http://freecircuitdiagram.net/wp-con...sing-LM338.gif Switching bulk converters LM2576HV - SIMPLE SWITCHER 3A Step-Down Voltage Regulator Or, the trick I have yet to discover. What is my best option? |
#3 |
I have heard that you can take a few turns off of the transformer to lower the voltage but I haven"t ever done it myself .....
#4 |
The transformer has a solid plastic core so I can't unwind the secondaries. Furthermore, I have too much pride for using a diode-stack to lower the voltage. I am interested in using a switching step-down solution, but I am a bit scared of the low switching frequency of the chip. (50kHz). I have found a lower ampere alternative with a 150kHz switching frequency. I might try that one, unless someone has a better idea
#5 | |
Banned
#6 |
Or just build Symasyms instead of the LM4780s.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#7 |
You know I am the guy who just built your LM4780 SS pcb right?
4 pieces of lm317 and 4 pieces of lm337 only cost 3,5 euro's, 4,5 dollars in total |
#8 |
If you can live with 35V a pair of mosfet cap multipliers might be the best way.
30V X 1.41 = 42V but you lose ~2v across the bridge rectifier so you have 40V and a pair of cap multipliers using mosfets will lose about 5V giving you 35V |
#9 |
I have been googling, but I can't seem to find a good example of a symmetric "cap multiplier using mosfet"-based psu. Can you tell me where to look for more information?
#10 |
2 caps, 2 resistors, 2-30V zeners, 2 power transistors, one heatsink - simple regulator.
| DC heater voltage 6 volts or 12 volts? | speakerfritz | Tubes / Valves | 7 | 8th October 2010 03:59 PM |
| Voltage Divider question - 6 from 12 Volts | Brit01 | Power Supplies | 14 | 14th August 2009 06:11 PM |
| power transformers 220 volts to 110 volts | garydmd | Chip Amps | 3 | 7th April 2007 02:52 PM |
| High DAC Output Voltage (2.7 Volts) | john65b | Digital Source | 4 | 29th December 2006 09:23 PM |
| Circuit to drop voltage signal from 5 to 1 volts (Computer S/PDIF ===> Home Theatre ) | zenon | Digital Source | 0 | 7th March 2006 04:08 AM |
| Page generated in 0.10568 seconds (79.59% PHP - 20.41% MySQL) with 11 queries |
