Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th January 2011, 09:29 PM   #1
Default help in rectifier diode selection
I am looking to build a 20A 13V power supply.
Which diodes should I use for the rectifier bridge?
I've been studying this one: http://www.vishay.com/doc?94242 rated at 30A 30V.
This has 3 pins but I do not know how to connect these in rectifier configuration.
I once built a rectifier with 4 shottky diodes but this one has 3 pins.
please help.
thanks.
Old 25th January 2011, 10:18 PM   #2
please help.
thanks.
You can't.
You would need 2 for a bridge and one would have a common cathode, the other a common anode. Draw a bridge to see what I mean.
Maybe there is another part with common anode?
Or you could use it as a full wave rectifier, but that would ned a centre tapped transformer secondary.
In any case, the ratings are not high enough. You need a higher reverse voltage and at least 3 times the load current rating, depending on the heatsink.
Google full wave rectifier, and do your own math!
Old 25th January 2011, 10:44 PM   #3
No wonder I was confused with the pinout.
I think I would be better with this component:
http://www.vishay.com/doc?93563 which is a single phase bridge.
I'm tapping the 0-15 ac from transfo.
Hoping this will be good for my psu.
thanks.
Old 26th January 2011, 07:25 PM   #4
thanks.
That's more like it! Much easier.
Get a 100V one, then you don't have to worry about calculating the voltage requirement.
Tube rectifier to diode bereanbill Tubes / Valves 19 19th May 2009 11:37 PM
BYV79E as rectifier diode tubee Solid State 5 18th June 2008 02:45 PM
diode rectifier ratings redrabbit Power Supplies 8 13th November 2006 05:33 AM
HV Diode Selection dsavitsk Tubes / Valves 6 10th September 2006 08:34 AM
Rectifier diode for Non-os Dac tonitze Digital Source 0 24th August 2003 04:33 AM
Page generated in 0.07437 seconds (76.41% PHP - 23.59% MySQL) with 10 queries
