Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th January 2011, 08:30 PM   #1
Default Simple transformer questions
Hi!
Im trying to design a power suppy for a lm4780 chipamp for my cerwin vega vs10 6ohms 125watts rating.
I have two toroid transformers, they are labeled 25V. Is it 25V RMS or peak?
They are not center tapped, can i still make a +/- voltage supply?
What voltage will i get after the rectifier?
I have a lot of free capactiors, is more capacitors always better?
Old 26th January 2011, 12:58 AM   #2
nigelwright7557's Avatar
25 volts RMS. About 36 volts after rectification.
You can make a dual supply from one transformer winding using 2 diodes.
But it will only be half wave rectified.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 26th January 2011, 08:37 AM   #3
mastodon's Avatar
+ and - 18V if you do as Nigel suggests. See here ('half wave rectifier'): Basic Rectifier Circuits
There's a law of diminishing returns. Based on the maximum load, run a simulation using a computer tool (e.g. Duncan Amp's PSU designer or LTSPice). Chipamps usually have a good power supply ripple rejection (PSRR), so you don't need as much filtering as you may think.
Old 26th January 2011, 09:37 AM   #4
OKay then.
Half wave rectifier will give me about +/1 11 V. That is way low.
If i could use both transformers, what is the best setup?
As i said i want to get as much power as possible for my Cerwin Vegas.
Old 26th January 2011, 10:32 AM   #5
Banned
Are the two transformers identical ?
If they are then it is a simple job to make a +/- supply.
Connect each transformer to its own Bridge Rectifier. You will then have two completely separate 35V DC supplies.
Then connect the +ve of one Bridge Rectifer to the -ve of the other Bridge Rectifier. This common point will be your 0V or Ground.
The unconnected -ve of the first BR will be -ve 35V.
The unconnected +ve of the second BR will be +ve 35V.
Old 26th January 2011, 12:32 PM   #6
Banned
It's as simple as that.
In your application you will probably need two regulators to bring the voltage down to a useable voltage as +/- 35V is probably too high.
Andy
Old 27th January 2011, 11:44 AM   #7
Originally Posted by frejohg View Post
I have a lot of free capacitors, is more capacitors always better?
adequate capacitance is always better.
More capacitance = bigger volume = bigger weight = bigger maintenance/replacement cost = bigger transformer and rectifier pulse current = bigger mains fuse = more risk of failure.
For 6ohms and reasonable bass performance I'd suggest +-10mF as the main smoothing capacitance. F-3dB of input filter ~5Hz giving ~10Hz for F-1dB LF bandwidth.
For excellent performance for all bass frequencies, I'd fit +-30mF for each channel for 6ohm speaker. F-3dB of input filter ~1.5Hz giving ~3Hz for F-1dB LF bandwidth.
BTW,
I can never recommend the dual version of the chipamp. It's manufactured to allow lower assembly costs for automated mass production.
regards Andrew T.
Simple Simple SE questions nodiak Tubelab 57 2nd February 2010 11:02 PM
Three Simple Questions!! Rob11966 Tubes / Valves 7 9th November 2007 10:17 AM
Simple questions. Help Please JustinSanders15 Multi-Way 2 12th May 2007 02:48 AM
Some simple little questions - Part 1 Mos Fetish Multi-Way 1 19th June 2003 05:37 AM
Some simple (for most, not me though) x-over questions Jimmy154 Multi-Way 0 29th December 2002 06:19 PM
Page generated in 0.09196 seconds (83.05% PHP - 16.95% MySQL) with 10 queries
