Go Back   Home > Forums > Amplifiers > Power Supplies
Old 17th January 2011, 03:25 PM   #1
Unhappy rotel RB-9708BX-mk2 AC 120 TO 220 HOW FIX
Please help !
I have bay Rotel 9....mk2 it have power supply from 120 V ~60 Hz , how to connect to 220 v Please help
best regards drago
Old 19th January 2011, 03:16 AM   #2
singa is offline singa  Singapore
Send a message via AIM to singa Send a message via MSN to singa Send a message via Yahoo to singa
Hi, For international power transformer there are 2 110 volt windings so if you want 110V Ac it is connected in parallel but I don't know what these 2 diode are doing there because normally only wire jumpers are used.Could be for polarity protection.
So if you want to use 220Vac you connect 110V coils in series.
Look at the other side of the pcb there are copper trace to the 2 110V
coils ,I think you may need to remove the two diodes and connect the
empty one at 220V but make sure it is in series to the 2 110V before
jumpering them with wire.Whether you need diode or not it's best if you can
get service manual. Ps you you are not sure find someone who knows
what to do regarding the diode. If not do not do it on your own.
Can I assume there is no switch at the back to switch to 22OVac?
Good luck.
Old 19th January 2011, 05:17 AM   #3
PS Before the switch to series connection (220Vac) pull power connector from main pcb and test only the transformer.If done right you will get same voltage
when wired as 110V primary at the secondary side provided you measure
110V/secondary output first to get =/- ? AC voltage. Singa
Old 19th January 2011, 02:18 PM   #4
thx everyone i sold it
I remove the links shown and fit one in the 230 position
220 to 120 volts convertor question sunny Power Supplies 3 7th January 2011 12:24 PM
KRELL KSA100 conversion 120 to 220 vac Guy alain Solid State 0 27th July 2010 09:22 PM
Rotel RC-850 Pre Amp + Rotel RB-870BX bleachershane Analog Line Level 4 9th February 2009 11:20 AM
still trying to fix my onix a-120... miekedmr Solid State 33 8th March 2006 12:50 AM
Hafler DH-120 and 220 ? Tino Solid State 0 11th January 2004 11:14 PM
Page generated in 0.08119 seconds (70.72% PHP - 29.28% MySQL) with 11 queries
