Power Supply for Class D: 12V AC
Old 16th January 2011, 01:57 PM   #1
mulluysavage is offline mulluysavage
Default Power Supply for Class D: 12V AC
I am learning diy audio, and my current project is designing an amp for a friend and plan to use a pre-fab PC board that takes 12V AC and outputs 2 channels at 100W each. I am trying to find/make a decent power supply. Can anyone make any recommendations and/or direct me to readings on *AC* power supply design for audio?
Old 17th January 2011, 12:09 PM   #2
mastodon is offline mastodon  Netherlands
mastodon's Avatar
So, let me get this straight: input is 12VAC, and output is, what? 12VDC @ 100W?
Old 17th January 2011, 01:04 PM   #3
DF96 is online now DF96  England
Does the PCB take 12V AC from a transformer? If so, you just need to safely wire a transformer. This would need quite a high current to supply two channels of 100W even for Class D: 20A in total? You would probably need a 400VA transformer.
100W seems a bit high for a first amp, unless you are just wiring together boards designed by other people. Even then it is risky - better to start at much lower power, especially if someone else is relying on you.
Old 17th January 2011, 11:33 PM   #4
Yes, board is pre-fab, 100W/channel, and they say it takes 12V AC in. Thanks for the tips about being responsible for another's amp, I want to make sure I do it 1. safely, and 2. so it sounds good. What about isolation? Clean sound?
Old 18th January 2011, 10:54 AM   #5
mastodon's Avatar
So that's essentially all you need. And some net entry, fusebox and any protection stuff you might fancy.
Old 18th January 2011, 12:16 PM   #6
You need to do some reading about mains safety in power supplies, as the mains side is the only thing you need to think about. Everything else is already decided by the amp modules you have chosen. Actually, not quite, you also need to learn about grounding.
Doing it this way you immediately have to do the two areas which can cause the most grief to newbies: safety and grounding. Not the place I would have started.
Power Supply for Class D: 12V ACHide this!Advertise here!
A good 12v power supply to run small class D amplifier indoors? chipper Power Supplies 2 16th June 2014 04:57 PM
18V AC+ 12V AC to +/-15V DC?? Elbert Power Supplies 8 24th July 2010 07:10 PM
chip amp with 12v DC AND 240v AC power supplies? Vital AV Chip Amps 19 15th November 2009 11:39 PM
12V AC to 6.3v DC simple supply for idiots DrewP Tubes / Valves 12 14th September 2009 03:06 AM
12V-220V(ac) to 12V-50V(dc) raszvan Car Audio 0 16th June 2005 09:28 AM
Copyright ©1999-2017 diyAudio
