Go Back   Home > Forums > Amplifiers > Power Supplies
Old 15th January 2011, 09:36 PM   #1
Default voltage multiplier current demands
Hello,
if i was to use a voltage multiplier to get 100v to 400v, how much more current would i need to power an amp? the overall current drawn from the amp is about 400mA and i have a 0-100v rated at 2A. will it reduce the curent i can draw without damaging the transformer? im thinking there might be something like 2X(100/400)=max current out, or is this wrong?
Old 16th January 2011, 05:29 AM   #2
singa is offline singa  Singapore
Send a message via AIM to singa Send a message via MSN to singa Send a message via Yahoo to singa
Voltage multiplyers don't have good efficiency as it is dependent on the
capacitor at the multiplyer stage that is the time constant or charging vs
the rectifying section be it silicon diodes or tube.400mA for high voltage
supply is not trivial.So for best performance it's best to use proper transformer
turns ratio ( step up) to get the high voltage you need.Singa
Old 16th January 2011, 07:42 AM   #3
Elvee is offline Elvee  Belgium
Voltage multipliers are a sub-variety of peak rectifiers, which means that for usual power levels and capacitance values found in electronics, the power factor will be around 0.5.
In order to get 400V output, you'll have to use a 3 stage multiplier.
Thus, IDC out= 2/(2*3)=0.333A.
This value is a crude approximation, and if you need more accuracy, you have to simulate the circuit.
voltage multiplier based on SS trafo - LONG ErikdeBest Tubes / Valves 33 10th September 2010 08:04 AM
phantom voltage multiplier cloudhopper Analogue Source 36 31st August 2010 05:05 PM
Voltage multiplier argonrepublic Power Supplies 27 25th February 2010 02:05 PM
Greinacher voltage multiplier EC8010 Tubes / Valves 10 24th January 2007 11:25 PM
Page generated in 0.06197 seconds (71.63% PHP - 28.37% MySQL) with 10 queries
