I'm trying to select an NTC for a Class A PS. The filter Caps add up to 108mf in a CRC configuration (54mf-R-54mf). The output is expected to be 16v at 4A.
In looking at NTCs, the Cmax ratings are far lower than 108mf. I also noticed in Nelson Pass' F5 PS he uses CL-60s. Their Cmax rating is 5mf. I must be calcuating something wrong, because NP has more than 5mf in his PS design. What Cmax does one use to chose the right NTC? |
#2 |
mf? Is this old American microfarads or misspelt mF = SI millifarads (=1000uF)?
#4 |
OK, I suspected that is what you meant, given the output of the PSU. It's just that the US was slow to adopt SI units, so m can still mean milli or micro when used by an American.
#5 |
A soft start system is rated in Joules, = 1/2 CV^2 or 13J which is not a lot. Look for an NTC which can handle 13 or more joules.
#6 | |
The manufacturer's data is for slow charging of capacitors where the NTC is in the secondary. These two arrangements do different jobs. Soft start is to allow the transformer to start up without blowing the close rated mains fuse. Slow charging is to reduce the peak current through the capacitor during charging.
regards Andrew T. |
#7 | |
just to be clear, putting on primary we have soft start & slow charge ,rigth?
#8 |
I don't agree, but I seem to be a lone voice that prefers a slow charge circuit to be designed exclusively to do that job properly.
regards Andrew T. |
| if an NTC thermistor is rated... | jarthel | Parts | 2 | 21st May 2007 12:06 AM |
| how to select an ntc thermistor? | jarthel | Parts | 7 | 2nd April 2007 10:00 PM |
| help with ntc thermistor | jarthel | Parts | 4 | 1st October 2006 04:57 PM |
| Which NTC to limit inrush current | Mlaen | Solid State | 24 | 10th February 2005 12:52 AM |
| Page generated in 0.09868 seconds (76.72% PHP - 23.28% MySQL) with 10 queries |
