Go Back   Home > Forums > Amplifiers > Power Supplies
Old 13th January 2011, 05:22 PM   #1
BigE is offline BigE  Canada
Default 4 pole caps and bypass caps
Does anyone use low value bypass capacitors with Jensen 4-pole caps?
I've replace the 5600 uf caps in my phase linear amp with 10K 4-poles @ 80 volts.
I'm thinking about installing a 0.47 uf between each supply rail and ground?
Will this be safe or will it overheat the 4-pole cap?
Thanks.
Old 13th January 2011, 05:26 PM   #2
Frank Berry's Avatar
The .47 uf caps shouldn't cause any problems and will certainly reduce the ESR at high frequencies.
Frank
Old 13th January 2011, 06:58 PM   #3
Thanks Frank.
Would there any point in putting a 10uF cap to feed each output and driver transistor instead?
I've read that this is a "good idea" but I don't know if it really matters.
Old 13th January 2011, 06:58 PM   #4
Gopher is offline Gopher  United Kingdom
Really Frank? I think you mean impedance not ESR since ESR is a fixed value that does not vary with frequency. The much larger ESR of a film cap in parallel with the much smaller ESR of a large electrolytic will make no discernable difference to the ESR of the electolytic on its own. Do you have specific manufacturer's data to back up this commonly held fallacy about HF impedance?
Old 13th January 2011, 07:08 PM   #5
Gopher, there is a graph that shows what you are looking for here:
http://www.intersil.com/data/an/an1325.pdf
Old 13th January 2011, 07:21 PM   #6
Big E
That graph only shows the way to prevent resonances when using multiple small value LOCAL bypass caps. The impedance of a large (10,000uF) reservoir electrolytic cap is several orders of magnitude less than that of a small (0.47 uF) film bypass cap at frequencies up to several hundred kHz. Adding the bypass cap in parallel does NOTHING to improve HF impedance (just do the sums) and can actually introduce audible resonances in the audio band.
Old 13th January 2011, 07:34 PM   #7
Thanks Gopher!
Interesting note, is that I saw this configuration in the service manuals for one revision of the phase linear 400, except the main PS caps were 5.6K uF and the bypass was 0.33 uF.
Odd that Bob Carver would fall for this.
The next revision did not include the bypass caps.
Old 13th January 2011, 07:41 PM   #8
Like you say, the bypass was removed. Maybe he listened instead of just believing the urban legend! Your Jensen 4 pole caps are specifically designed for very low inductance/HF impedance. If you add bypass caps you could screw that up.
What's far more important is having substantial LOCAL elecs at or near the output transistors in addition to the main reservoir caps. Anything from a few hundred to a couple of thousand uF should do nicely, depending on the power output. A small value resistor before the local caps would help too.
Old 13th January 2011, 10:19 PM   #9
tatus is offline tatus  Germany
If you refer to what they have done in that app note on pages 6 and 10: that is complete nonsense: they are adding magnitudes of complex functions (real and imaginary parts) over frequency. What happens in reality is that small capacitances together with stray inductances of large capacitances form a resonant circuit, creating very high impedances at certain frequencies. As a result, adding capacitance without clearly knowing all relevant parameters of all parts (for each capacitor at least besides C: stray inductance and ESR), things tend to get worse than before. The stray inductance is normally not specified but can be calculated from the resonance frequency when the impedance graph of the part is known. Then run a spice simulation to see what makes sense.
Furthermore: small bypass capacitors only make sense very very close to the load. If placed in parallel to the large supply capacitors, the long lead to the amplifier creates another inductance that renders all positive effects void.
Old 14th January 2011, 01:39 PM   #10
Thanks!
If anything, I may try adding reservoir caps right at the output transistors.
This site is fantastic! Maybe one day, I'll know enough to contribute....
Thanks again!
Jensen 4 pole caps SatChitAnanda Parts 10 3rd June 2010 03:01 PM
bypass caps for bypassing mylar caps? crippledchicken Multi-Way 4 27th February 2008 04:24 AM
WTB: Jensen 4 pole caps max29 Swap Meet 0 7th November 2007 08:03 AM
Value matching 4-pole caps novec Parts 0 13th November 2006 09:08 PM
Bypass caps on crossover caps... :D quickshift Multi-Way 19 27th November 2005 12:59 PM
Page generated in 0.09837 seconds (85.67% PHP - 14.33% MySQL) with 10 queries
