Hello to all!
first thread in this forum I recently found a 100W 30V smps (from an old printer I guess) and i think of using it as the power supply for a small gainclone i m building (2x10watts with lm1875 at+-15V) Using such a circuit would be ultra lo-fi ??? i think that its gonna work but i wouldnt like to end up with a noisy little amp.. My other option is a standard regulated psu..i already ave one 50VA toroid and i think that its enough for a 2X10 W gainclone, but most of the online projects use as big as it gets transformers wich i cant understand much why??? any help ??? Thanks and sorry if i have posted in the wrong place |
#2 |
Did it Himself
Capacity wise it should be fine, your problem is going to be having to create a virtual earth which the speaker currents can return to. Stick with a traditional transformer supply if you are a beginner.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
Thanks for the reply.
not a total begginer, i have an understanding in electronics, but i m sure i can learn from more experienced people (smtmz even from less I mean using a topology like the one in the link to create the virtual ground, not exactly the same circuit.I think the transistors and the diodes wont be able to handle the current. I find some other topologies for virtual ground on the net using opamps, but i have never again used high current opamps (except in gainclones in a way..) In general, using a virtual ground to split a voltage supply would have noise or other unwanted effects ? Any topology to suggest ? Thanks! p.s: this is a nice link explaining virtual ground circuts |
#4 |
You could also use a bridged amp setup. This way your virtual gnd would only have to handle the the input signal level currents.
#5 | |
The transistor bridge only has the job to split the supply in two nice halves, and to keep that level. Keep in mind the current drawn from your circuit is pure AC. Taking this to the top: when there would be such device as two capacitors without any leakage current and with identical capacity, you yould even completely omit that circuit. The two capacitors then would split the supply into two identical halves by themselves. Google for "capacitive divider", which is similar to a resistive divider but lossless and only for AC signals. |
#6 |
considering an AB class amp, in the first half of the cycle where the current is drawn from the positive supply rail (and returns through the virtual ground), shouldnt the transistor's CE current be capable to hold the same amount of current that the load demands ?
I think i ll go with a regulated psu, but i want to try out such a circuit..if i come up with a toasted transistor i ll post back here Thanks! Aris |
#7 |
Using a bridged topology would eliminate the need for a large current return to a virtual GND or a DC blocking output cap. You can use a higher Z floating reference halfway between B+ and GND 0V as the input source common so the output of each amp will be halfway between the B+ and 0V. This is the best way to get 0VDC output from a single end power supply, especially with only 30V. 50Wrms @ 8R is possible from full bridge topology.
All the trouble I've ever been in started out as fun...... |
#8 | |
The important thing is that the current flowing through the speaker is pure AC, which means that both capacitors are ALWAYS discharged by the same rate over time. Try this circuit, make sure that the transistors can withstand the full supply voltage plus margin (I mean from + to -, not from + to "virtual gnd"). Keep the balancing currents flowing through them small enough so they do not get overheated. You can even start with a transformer, a rectifier, two capacitors and two resistors across them. Works just as good. What is important here is that the amp itself draws approximately the same idle current (no signal, speaker disconnected) from both supply rails into GND. You should measure this to be sure. The more imbalance you have the smaller the resistor value must be. |
#9 |
My proposal does not have 4 times output power as your has, but it does has advantages: simpler, cheaper. Just two resistors in the simplest case. And no turn-on pop as for the "standard" method of adding a capacitor in series to the speaker.
#10 |
Hi!
i m posting here again so as not to start a new thread.. i m about to test a rail splitter like this one i want to split a 30Volts into +-15 and i m not to sure what should the rating of the capacitors be...25volts would be ok ??? i run a quick n dirty simulation with psim of the divider with a resistive load showing that the voltage across each capacitor is from zero to nearly 15 volts... so this is the schematic and the voltage across one capacitor. also for 1,5 amperes at the positive rail (through the resistor from +15 v to ground) there is 1,5uAmperes at the emitter of the respective transistor |
| How to spilt one channel out from stereo for woofer | chchyong89 | Chip Amps | 16 | 24th April 2009 01:11 PM |
| Supply SMPS transformers | panxuyan | Vendor's Bazaar | 1 | 7th March 2009 12:31 PM |
| Irrelevent stuff spilt from Cap selection thread | SY | Everything Else | 120 | 17th June 2003 02:33 PM |
| Page generated in 0.12054 seconds (81.85% PHP - 18.15% MySQL) with 11 queries |
