Go Back   Home > Forums > Amplifiers > Power Supplies
Old 15th December 2010, 03:23 PM   #11
I have purchased transformers that were very much in saturation at normal line and also maybe with 20% to go. It's Totally up in the air. If you didn't design it you can't guess, although it's easy to tell once you plug them in. No load temperature rise and noise is a dead giveaway. I have some Talema 200VA toroids that must draw a watt or less at idle, and I think I paid 10 bucks a piece for them. Then I recently bought some Dayton plate amps and had to throw out the supplied transformers because they got hot just sitting there. I think they laminated them out of tin cans and put on about 3/4 of the required primary.
Old 15th December 2010, 06:14 PM   #12
DF96 is offline DF96  England
Saturation in a transformer is independent of the load current.
There was a long discussion about this somewhere. The conclusion was that load current reduces core flux by creating ohmic drop in the primary. Not a huge effect, but if a mains transformer is not saturating off-load then it will not saturate at any load.
Old 16th December 2010, 06:08 AM   #13
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
To clarify one point.
Measuring the Primary current with the secondary open circuit. Is that the same as measuring the primary current with the secondary removed?
yes.....no load current consisting of magnetizing(exciting current) and hysterissis/eddy current losses
Old 16th December 2010, 06:13 AM   #14
Tony's Avatar
I wind power supply transformers with a maximum of 1,2 T at 230 Vac. Mostly not over 1 T.
i wind my traffos at 0.7T, cores available in my country are not so good compared to M6 irons from the states...
Old 16th December 2010, 07:43 AM   #15
Designing for 130/260V rms WHEN HOT is probably enough
Old 16th December 2010, 10:09 AM   #16
That's the second time "hot" has been mentioned.
What is it about "hot" that makes the test condition more severe?
regards Andrew T.
Old 16th December 2010, 11:19 AM   #17
Tony's Avatar
there is such a thing as a 10 second rule.......if you hold the traffo in your hand and you are able to stand the heat for 10 seconds, then the traffo is not that hot.....
Old 16th December 2010, 11:47 AM   #18
all my own design gear that is mains driven run with the transformer feeling almost cold.
I have touched some plug in the wall type transformers that get too hot to touch !
regards Andrew T.
Old 16th December 2010, 11:54 AM   #19
Tony's Avatar
these are the traffos that i have made recently:
Old 20th December 2010, 01:11 AM   #20
Winding resistance goes up with rising temperature, causing output drop and a potential runaway problem.
I don't think iron saturation varies too much with temperature, unlike ferrite which performs badly when it gets warmer eg Powdered-Iron and Ferrite Materials for Inductor Cores Page of
Using primary as the secondary winding in the power transformer. mishak Parts 10 30th May 2010 05:55 AM
Transformer primary winding question gary h Power Supplies 4 21st December 2008 06:21 PM
Calculating Bmax and primary turns etc... guitar_joe Power Supplies 4 5th July 2007 09:06 AM
shorted turns in primary? mrshow4u Solid State 15 12th September 2006 05:09 PM
Winding toroids, turns vs core area johan Parts 2 28th September 2001 08:44 AM
Page generated in 0.10503 seconds (78.05% PHP - 21.95% MySQL) with 10 queries
