Go Back   Home > Forums > Amplifiers > Power Supplies
Old 14th December 2010, 05:12 PM   #21
bobodioulasso's Avatar
Why not to use the Cviller board version using double outputs and cascoding.
And reduce by a few volts only the rails using the zen cap multiplier.
The extra power would be dissipated into the output devices instead of a (doubtfull for class A) regulation.
At the end , at equal dissipation, you will get a more powerfull amp.
In anycase you need bigger heatsinks than standard F5.
Voltage regulation for TL494? thunderpld Power Supplies 0 14th March 2009 10:28 PM
Thyratron voltage regulation rcavictim Tubes / Valves 2 2nd March 2007 09:25 AM
Voltage Regulation from a battery bigphil Power Supplies 9 14th October 2006 03:44 PM
need a high amperage, low voltage rectifier... Stuart Easson Parts 5 5th November 2004 05:02 AM
Regulation options for 807 g2 illuwatar Tubes / Valves 13 31st August 2004 04:33 PM
Page generated in 0.05668 seconds (74.20% PHP - 25.80% MySQL) with 11 queries
