Availability of 3-phase AC mains supply at High-power Audio Installations
Old 1st December 2010, 11:37 AM   #21
SemperFi is offline SemperFi  Wake Island
Originally Posted by zigzagflux View Post
Hmmmm. Current travels at the speed of light, regardless of capacitor size and ripple frequency, but I understand your point. However, if we consider a 20 kHz signal, it really makes no difference if we are dealing with 100Hz or 300Hz recharge on the power supply capacitors. I would argue the same for the rising edge attack of a kick drum; by the time the dynamic attack has started and is over, a 300Hz recharge is actually quite slooooow, and cannot provide recharge fast enough.
The real advantage of higher ripple frequency is a reduced requirement on the LC filter size; this results in a lower source impedance as seen by the output stage. Apples to apples, three phase rectification results in lower peak-to-peak ripple.
Side note
To really get deluxe in the European DIY community, ...result in a 12 pulse rectifier. Now we're talking increasing our rectifier ripple to 600 Hz. Heck, take it another step with zigzag windings, and you can get out to 1200 Hz. As nice as this seems, the cost and weight of the iron just isn't worth the cost of a capacitor.
I think he means the response of the cap, not the general electron flow. Some people claim smaller caps respond quicker to dynamics...
I agree the cost of such a system just doesnt make up for it. Tho for the sake of going beyond, go for it...
Old 1st December 2010, 12:45 PM   #22
imix500 is offline imix500  United States
imix500's Avatar
Actually, speaker arrays are getting more and more efficient. Considering the output capabilities of your average amp rack for those systems, they don't really waste that much energy at idle. Things get even better if those arrays are self powered and the amp modules have been designed for the cabinet they are in. Also, unless you are hosting DJ Tiesto or the like the average power consumed isn't that high.
Lighting is getting better too. Very few if any large acts are using hundreds of 1k par cans anymore. That's a bit 1980's to most. LED fixtures, LED video walls, more efficient ballasts for the HID lamps in intelligent fixtures and large video projectors, and the use of video driven LED based fixtures as part of the lighting design have notably cut down on power consumption.
Old 1st December 2010, 04:37 PM   #23
multisync is offline multisync  Canada
zigzagflux
the motor ran a hollow drum at 5000RPM. The outside of the drum was a negative with 132 rows of characters on the negative. Inside the drum was a bank of strobe lamps. When the right character was in front of the right strobe lamp the lamp would flash and project an image of the character to a print drum and voila! electronic printing. Long before laser printing. Oh yeah, only one character set, only landscape, only single sided, only 20lb paper, only 8 1/2 by 11inch paper and no graphics.
Old 1st December 2010, 04:49 PM   #24
dmills is offline dmills  United Kingdom
The subtle point with modern lighting is that while something like the "Bomber rig" switched banks of lanterns so only part of that massive number of parcans was on at any one time, the modern discharge stuff is struck at the start and runs continuously right through.
Lighting is still the power consumption king.
Now 208 or 220 split phase possibly makes sense in the US because of the massive weight savings, less current means less voltage drop and the higher voltage means that a given voltage drop matters less to start with, but I don't see genuine three phase input amps ever really being a mass market product.
Regards, Dan.
Availability of 3-phase AC mains supply at High-power Audio InstallationsHide this!Advertise here!
audio over mains supply? jimbo1968 Everything Else 11 17th July 2013 07:19 AM
35khz High Frequency AC Supply (Tube design) CivicProtection Power Supplies 3 21st May 2010 06:53 AM
High end Switch Mode Power supply for Audio Petter Parts 29 5th May 2010 07:42 AM
Power supply:Universal AC input/ Full range,High Efficiency, and High reliability hang Vendor's Bazaar 12 24th July 2009 04:46 AM
high AC mains problem atenolol50 Tubes / Valves 7 25th September 2008 05:11 PM
Copyright ©1999-2017 diyAudio
