Keantoken's CFP cap multiplier
Old 8th September 2013, 09:23 AM   #501
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
well, in my experience, bigger VA tx sound better but I do not see how a circuit consuming steady 300mA would cause saturation on a 80VA TX
RC
Old 8th September 2013, 09:44 AM   #502
R.I.P.
I was led to believe that saturation is worse at very low loads and made worse by high supply voltages.
Increasing the output leads to increased IēR losses.
Does increasing the output also increase the risk of saturation?
regards Andrew T.
Old 8th September 2013, 06:39 PM   #503
keantoken is offline keantoken  United States
keantoken's Avatar
I've looked at the output of a 350VA toroid I have. Yes, there are flat tops to the sine wave but the flat tops always have the same geometry when I increase the voltage, it can't be a saturation issue. Rather it must have to do with line impedances earlier on which resist the charging pulses. I got up to 6.66A and couldn't test further because my graphite resistor submerged in water (affordable power resistor!) wouldn't go less than 3.3R for mysterious reasons.
There are actually two kinds of saturation which confuses the issue. There is flux saturation, which occurs when input changes fast enough, so it happens at the zero-crossings. I observe this with my toroid. It happens worst when the transformer is not loaded, because loading it relieves the magnetic stress. Because the rectifiers don't conduct during zero-crossings, toroids must avoid this form of saturation because the primary acts like a short as it happens. The second kind is the kind usually discussed concerning transformer power ratings. This is current saturation where inductance falls along with output, and this also causes an input current spike I think. I read that current saturation in a toroid makes flux saturation much worse, which is why toroids can have monstrous inrush current.
All of my measurements suggest the issue of perceived power in amps has little to do with transformer rating, but everything to do with supply filtering and transformer impedance. I have a very simple Lfet power buffer which sounds like it's lost it's bass when I don't use a line filter. A large trafo can sound very weak if you mess up the amplifier circuitry.
So this leads me to think that someone who knows what they're doing does not need to pay for an oversized transformer. My 350VA 55-0-55 toroid gives more than 6.66A peak without saturating, which is at least 518W. I don't think dynamic power can be an issue.
The secondary only supplies the same average current as is drawn by the load, so any saturation losses must be caused by charging pulse width, which does not seem to change much depending on reservoir capacitance except at very low currents. In a sane simulation model, line impedance and transformer leakage inductance act as the current limit, so the charging pulses across 4 octaves of capacitance is almost identical. You would need to severely undersize the capacitance to change the pulse shape.
So, impedance and filtering are the only things that add up here.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 8th September 2013, 06:54 PM   #504
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
if there is a high frequency spike/ressonance, would it change frequency with cap size ?
or could there even be more than one spike/ressonance with multiple caps ?
sometimes we know very little, and sometimes we know too much
Old 8th September 2013, 07:56 PM   #505
keantoken's Avatar
There are numerous resonances in any power supply unless one takes the effort to measure each one and damp it. This is not as straightforward as it seems because all the impedances change when the rectifier conducts, from very high impedance to very low impedance.
If you damp all resonances in one condition you may get even worse resonances in the other condition.
Old 9th September 2013, 05:42 AM   #506
nhinstruments
RCruz's Avatar
From your findings I take it that my subjective listening impression results have more to do with the type of transformer than it's VA rating (IMO, in my application, a Rcore outputting 300mA at 45vdc sounds much larger and refined than the same using a toroid.)
Would you please comment on that ?
Also, why low output currents do cause higher saturation ?
PS:; With Kmultiplier on my paradise psu TX heats much less than before.... why should this happen ?
RC
Old 9th September 2013, 06:11 AM   #507
keantoken's Avatar
The trafos in your pictures have split bobbin windings which means that capacitance from mains to amp will be very small. This means very little ground noise. Furthermore non-toroid transformers have more leakage inductance and core losses which means they filter more RF inherently.
Low output currents usually don't cause more saturation because flux saturation occurs when the rectifiers are not on. If you added a load before the rectifiers you may reduce flux saturation but it certainly wouldn't be efficient. Flux saturation occurs when the voltage crosses zero; if the trafo has enough loading during this time, which it will not because the rectifiers aren't conducting, then there will be no flux saturation. It would be interesting to experiment with to see what the affect on sound is.
I seem to recall looking at the Paradise PSU that I worried the regulators would be unstable. If so adding the Kmultiplier may change impedances and stop it by random luck. But I don't know why a Kmultiplier would cause a transformer to run cooler. That's a new one to me. If total capacitance had anything to do with charge pulse current, than I would suspect that the Kmultipliers were blocking ripple so that the transformer isn't charging all the capacitors after them. But that does not seem to be how it works.
Old 9th September 2013, 07:56 PM   #508
nhinstruments
RCruz's Avatar
Originally Posted by keantoken View Post
The trafos in your pictures have split bobbin windings which means that capacitance from mains to amp will be very small. This means very little ground noise. Furthermore non-toroid transformers have more leakage inductance and core losses which means they filter more RF inherently. Maybe that is why I like R-Core so much
Low output currents usually don't cause more saturation because flux saturation occurs when the rectifiers are not on. If you added a load before the rectifiers you may reduce flux saturation but it certainly wouldn't be efficient. Flux saturation occurs when the voltage crosses zero; if the trafo has enough loading during this time, which it will not because the rectifiers aren't conducting, then there will be no flux saturation. It would be interesting to experiment with to see what the affect on sound is. Maybe I can place a small RC between the TX and rectifier to load the TX during the zero cross
I seem to recall looking at the Paradise PSU that I worried the regulators would be unstable. Not mine because I used special jap power transistors as per Salas advise... If so adding the Kmultiplier may change impedances and stop it by random luck. But I don't know why a Kmultiplier would cause a transformer to run cooler. That's a new one to me. If total capacitance had anything to do with charge pulse current, than I would suspect that the Kmultipliers were blocking ripple so that the transformer isn't charging all the capacitors after them. But that does not seem to be how it works.
Cooling might have more to do with my new layout after all.
RC
Old 9th September 2013, 09:49 PM   #509
keantoken's Avatar
Try a large cap like 4.7u, and try it with and without a 22R series resistor (or use a 50R trimmer if you want). I'd be interested in hearing your results. This is what I've done actually, but it was in the interest of damping winding resonances rather than eliminating flux saturation.
Old 10th September 2013, 02:54 AM   #510
BenY is offline BenY
I didn`t read the whole thread, but would like to add...
When a rectifire starts conducting the charging current lowers the secondery voltage output , So the diodes start bouncing ON/OFF riding on the regulation margin of the tranny. this happens till the charging cycle voltage increases above the transformer regulation margin, Then the diode remains open till the closing cycle occures..
This usually happens with ultra fast diodes..
To eliminate or minimize the regulation margin of the transformer a simple load resistor/s across the secondery output will do the job quite effectivly.
Keantoken's CFP cap multiplierHide this!Advertise here!
Vbe multiplier - bypass cap Donk Solid State 7 22nd January 2008 01:55 AM
Question(s) about CFP. Justcallmedad Solid State 94 20th September 2005 10:08 AM
cap multiplier or not? PederBass Solid State 13 23rd March 2004 06:26 PM
Cap. multiplier or regulated supply ? Buhl Pass Labs 1 8th October 2003 10:51 PM
