Keantoken's CFP cap multiplier - Page 4 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 10th October 2010, 10:12 PM   #31
keantoken's Avatar
They should work fine. Phillips datasheet specifies 190MHz/NPN 160MHz/PNP, which is really good. I have been weary of these since for some reason the purveyors don't seem to think that stating the Ft or Cob on the datasheets would be a selling point. Phillips got smart, but even their datasheets don't state Cob.
- keantoken
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 12th October 2010, 09:18 AM   #32
Keantoken,
Thanks a lot. I am as busy as usual but will send you a private email with a bit more information about the Marantz reg when I have the time in the coming couple of days. My current job is with a government department and they restrict forum access so I can only access the forum at night when the day is done.
Bill
Old 18th October 2010, 04:48 AM   #33
keantoken's Avatar
Default The K-Multiplier is born
Okay, here goes...
I have been consulting HiFi to create a preregulator that matches his application, and this is what I came up with. It is pretty much a Hi-fi C-multiplier. I call it the K-multiplier.
It will handle any load up to 1A, because the voltage across the outputs is limited to 2.7V - 1A*2.7=2.7W. I would not recommend drawing more than 200mA, since this gets into the outputs' low-beta region and performance will drop.
Voltage drop is about 2V. This can be decreased to about 1.3V if we bypass, say D5. However, a large drop in input will saturate the 2N5xx1 transistors.
This is designed as a prereg, not for high-ripple conditions. It is to improve the performance of later regulators. It will work in high-ripple situations, but you should add diodes to the string D1 and D5 depending on how much ripple you have.
HiFi encouraged me to post this here, and I might as well post the finished design, so someone can spot my errors...
- keantoken
Old 18th October 2010, 07:45 AM   #34
Eric Juaneda's Avatar
Hi keantoken,
Many thanks for all your work and simulations.
I have interrogation about using 1000F. Since this design is a capacitor multiplier, it will multiply everything coming from this capacitor. It will multiply good effects and bad effects (like coloratura, non linearity...!). Don't you think that using 100F or 10F might be more realistic?
Probably, it will be easier to find good 100F than good 1000F.
Thanks for all replies...
Eric Juaneda - tech.Juaneda.com - Junilabs.com
Old 18th October 2010, 07:51 AM   #35
keantoken's Avatar
There won't be any measurable degradation from using a 1000uF cap that I can see.
100uF is totally fine, the bass at audio frequencies will hardly be affected.
- keantoken
Old 18th October 2010, 07:57 AM   #36
keantoken's Avatar
Wait, the schematic had an error! Here is the correct schematic.
- keantoken
Old 18th October 2010, 08:08 AM   #37
You could not see any coloratura in any simulator
This simulation goes to 1GHz. Do you think that 1000F is able to work at 1GHz?
Old 18th October 2010, 09:08 AM   #38
keantoken's Avatar
No, surely not, but I look anyways. You can always bypass that cap with smaller film caps.
The regulator should be decoupled by at least 10uF.
BTW, it is a joke to take credit for this circuit. Nothing special!
- keantoken
Old 18th October 2010, 09:53 AM   #39
reversing that diode seems to make a big phase difference.
Why is the PNP performing better this time over most of the frequency range?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 18th October 2010, 10:12 AM   #40
keantoken's Avatar
Beta characteristics of the master transistor will affect bass performance. Beta characteristics of the slave will affect output impedance.
- keantoken
Vbe multiplier - bypass cap Donk Solid State 7 22nd January 2008 01:55 AM
Question(s) about CFP. Justcallmedad Solid State 94 20th September 2005 10:08 AM
cap multiplier or not? PederBass Solid State 13 23rd March 2004 06:26 PM
Cap. multiplier or regulated supply ? Buhl Pass Labs 1 8th October 2003 10:51 PM
Copyright 1999-2017 diyAudio
