Keantoken's CFP cap multiplier
Old 26th January 2013, 11:19 AM   #331
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
got it, thanks...it works
tricky, because those caps must be some kind of small wonders, since they seem to hold voltage almost indefinately
drained the caps with a reisistor....and he LED flashes nicely on power up
thought I wouldn't need a LED/res supply drain/bleeder, because of the LED in curcuit, but seems I have to mount one
will use for powr on indicator on front panel
Originally Posted by keantoken View Post
BTW, that's a super-stylish trafo there.
ripped from a wallmount supply
Old 27th January 2013, 10:49 AM   #332
keantoken is offline keantoken  United States
keantoken's Avatar
Neat! You turn it into gold. Is that wood? At first I thought it may be something nifty and esoteric but now I realize it's just to hold the trafo in place? For the top part it looks like you drilled holes and cut it out with a band saw? I need to learn this sort of resourcefulness.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 27th January 2013, 08:10 PM   #333
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
I am starting to cllect parts for the Kmultiplier I am going to use with the JG Paradise.
The Paradise uses shunt psu and draws 150mA on each positive and negative PSU, working at +-18V.
Due to availability I would like to use D45H11 power PNP instead of 2SA1930 for the positive kmultiplier.
For the negative one I have D44H11
Can I use those instead ?
Best regards
RC
Old 27th January 2013, 08:32 PM   #334
keantoken's Avatar
That transistor is a whole lot slower and I don't know about its quasisat behavior. I would have ordered some to test out but they were out of stock when I last had the chance. I tried some other outputs but the C5171/A1930 seem to be important to the specs of this design.
Old 27th January 2013, 08:37 PM   #335
nhinstruments
RCruz's Avatar
Ok... I will order some
Do these need to be heatsinked ?
For the other trannies I have the BC337/327.
I read your text describing the circuit but I am having difficulties following all parts purposes.
What is the purpose of the 820u cap ? Does it get multiplied as in a darlington C multiplier ?
RC
Old 27th January 2013, 09:23 PM   #336
keantoken's Avatar
The 820u cap is multiplied like in a C-multiplier.
The C5171/A1930 should not need a heatsink at 150mA since they are dissipating only 300mW.
Old 27th January 2013, 10:17 PM   #337
Is that wood?
hey, I suppose you mean the brown trafo 'chassis' ? ... I think it's Pertinax
its hard pressed paper/glue, and very strong
I just cut with an ordinary metal handsaw, and dress with a file
edges are difficult, and splinter easily...could be better
the rest of the box is scrapped digital 'something', modified a bit, and some plywood
it's really way too much work for what it is, but whatever, its great fun
Old 28th January 2013, 02:38 PM   #338
and got the Kmultiplier mounted
and since its a topic/thread with few pictures, I give you some
Old 28th January 2013, 03:30 PM   #339
keantoken's Avatar
Thanks for the pictures. I can't imagine using a hand saw and getting something to fit together as a box. If I knew of a way of a way to cut wood well enough for boxes I'd have my own sealed speakers probably.
Old 28th January 2013, 04:38 PM   #340
nhinstruments
RCruz's Avatar
Nice work tinitus
RC
Keantoken's CFP cap multiplierHide this!Advertise here!
Vbe multiplier - bypass cap Donk Solid State 7 22nd January 2008 01:55 AM
Question(s) about CFP. Justcallmedad Solid State 94 20th September 2005 10:08 AM
cap multiplier or not? PederBass Solid State 13 23rd March 2004 06:26 PM
Cap. multiplier or regulated supply ? Buhl Pass Labs 1 8th October 2003 10:51 PM
