Keantoken's CFP cap multiplier
Old 18th December 2012, 04:49 PM   #301
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Kean, in post 293 I see you changed the 327/337 from -25 type to -40 type ?
Old 18th December 2012, 05:28 PM   #302
keantoken is offline keantoken  United States
keantoken's Avatar
I keep waffling, in simulation all the gain groups act the same so I use the -40 gain group when convenient. The models are from NXP/Phillips and always seemed to be very good quality, so I would not be surprised to find the -40 gain group working as expected in reality.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 18th December 2012, 10:28 PM   #303
about how to test it when built
I suppose it works ok if it shows the expected voltage drop of 1.5V ?
ah, the *Troubleshooting* chapter on your website
Old 19th December 2012, 12:55 AM   #304
keantoken's Avatar
Old 19th December 2012, 11:14 AM   #305
the SMPS issue brought up here could have another interesting angle/aspect
I have a box loads of those standard wall plug thingies
tried to use one with my guitar effects
but even with this a simple regulated DIY supply sounds better
now Im thinking if the K-multiplier might help to filter the SMPS
but should be easy to check
Old 20th December 2012, 01:19 AM   #306
KlipschKid is offline KlipschKid
You could build Tangent's low noise measurement pre-amplifier :
Low Noise Measurement Preamplifier
I have an old 12Mhz scope that goes down to 1mV, and my Fluke is only accurate to 1 or 2mV too, so I'm stuck for precise measurement - so I follow theory and let my ears decide. After all, I do this hobby because I enjoy listening to music as well as making things.
Old 20th December 2012, 08:43 AM   #307
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Hello Kean,
Could I replace BD139 with MJE340 or KSE340?
C1 have to be rated 400V?
Old 20th December 2012, 09:04 AM   #308
keantoken's Avatar
I would not. It probably has terrible quasi-saturation parameters.
Old 20th December 2012, 09:06 AM   #309
Ok I will order BD139, wich voltage required for C1 82uF? All resistor 1/4W, metal or carbon? LEDs 2V 20mA?
Old 20th December 2012, 09:21 AM   #310
keantoken's Avatar
C1 should have the same voltage rating as your reservoir caps. All resistors can be anything 1/4W.
Keantoken's CFP cap multiplierHide this!Advertise here!
Vbe multiplier - bypass cap Donk Solid State 7 22nd January 2008 01:55 AM
Question(s) about CFP. Justcallmedad Solid State 94 20th September 2005 10:08 AM
cap multiplier or not? PederBass Solid State 13 23rd March 2004 06:26 PM
Cap. multiplier or regulated supply ? Buhl Pass Labs 1 8th October 2003 10:51 PM
