#21 |
It still acts to multiply capacitance, with the same drawbacks in that regard as a normal multiplier. The difference here is that the output voltage has been largely shielded from variations in supply voltage, via filtering (CCS, capacitors, diodes). In this case bass extenstion will be the best, because of the high source impedance (CCS) which will give the capacitor/s a large time constant.
I like your circuit Storm, and using the CFP will improve it's performance quite a bit. I was right, NPN BJT is better, but CFP is still worse for HF impedance. - keantoken
Contribute to the DIYAudio WIKI! http://www.diyaudio.com/forums/every...p-sign-up.html LTSpice wiki with special attention to new users' troubles |
#22 |
It looks like in StormSonic's circuit the capacitor can be eliminated completely with little impact on performance, except perhaps noise.
- keantoken
#23 | |
post1216 shows a regulator.
It is a follower just like Pass often recommends. The output voltage = Vbe + LED Vf. and removing the capacitance proves it is not a capacitance multiplier Quote:
regards Andrew T. Last edited by AndrewT; 6th October 2010 at 11:19 AM. |
#25 |
Thanks, guys.
Keantoken, Could you provide a "final" C-Multiplier schematic including selected transistors that are ready to be built? Some pictures of simulations are welcome. I am happy to be a builder/tester here. The result is a C-Multiplier of your design. Given the circuit won't be complicated so part counts and price are of no issue. It needs to have both rails of around +/-17VAC (after rectification) input, with a voltage drop (2 x 0.65V?). I will put it in front of the Iko reg (+/-29VAC though) for the first test, and if successful, put it in my Marantz CD player before the Marantz reg. I will report how it sounds here. Regards, Bill |
#26 |
First thing, you said Marantz used a "very simple" series reg. Can you tell what type it is? Does it use feedback (good impedance), or not (normal BJT impedance)?
In both cases, using a low output impedance prereg may be a waste of effort, because the circuitry will see the Marantz reg's impedance no matter what. Knowing this I will focus on line rejection rather than output impedance. Can you describe the regulator voltages in more detail? Earlier you stated 15V input voltage. The 1.3V drop limit is difficult to work with, because bias resistors necessarily add to the Vbe's already present between input and output. Is it okay to go higher than this? - keantoken
Contribute to the DIYAudio WIKI! http://www.diyaudio.com/forums/every...p-sign-up.html LTSpice wiki with special attention to new users' troubles Last edited by keantoken; 10th October 2010 at 03:05 AM. |
#27 |
This circuit has the lowest voltage drop and output impedance, with a good PSRR of -54db. If higher voltage drop is allowed, better specs can be achieved. I doubt this is necessary though.
Choices for Q1 in order of order of decreasing preference: MPSA18 2N5089 2N5210 2N4401 2N2222 BJT's with lower gain may be used, but voltage drop will suffer. For Q3, choose the highest gain normal PNP transistor you can find. Even so, output drop may be around 300mV worse than the NPN version. Decreasing R4 can fix this, but will change the bass response and I imagine you want the bass response for + and - regs to be equal. For the power BJT's, anything you would use in an audio amp should work, but if in doubt ask. - keantoken
#28 |
For C1 and C2, bigger is always better. These will delay turn-on however.
For the power BJT's, the 2SC5200/A1943 seem to work best in simulation. Following are the MJL1302a/0281a. However these are power BJTs, good to 10A or more - what output devices are used for the Marantz reg and their current rating? How about downgrading to 2SA4793/C1837? This improves BW considerably, to over 100KHz for both NPN and PNP, at -64db PSRR. - keantoken
Contribute to the DIYAudio WIKI! http://www.diyaudio.com/forums/every...p-sign-up.html LTSpice wiki with special attention to new users' troubles Last edited by keantoken; 10th October 2010 at 05:01 AM. |
#29 |
Here is the output impedance using the 2SC4793/A1837 pair. This rivals some of the best electrolytics I have measured. It would be hard to improve on this using anything but film caps.
- keantoken
#30 |
How about the lowly BD139/BD140(-16). Should be easier to get and have with similar specs?
Martin Rupp |
| Vbe multiplier - bypass cap | Donk | Solid State | 7 | 22nd January 2008 01:55 AM |
| Question(s) about CFP. | Justcallmedad | Solid State | 94 | 20th September 2005 10:08 AM |
| cap multiplier or not? | PederBass | Solid State | 13 | 23rd March 2004 06:26 PM |
| Cap. multiplier or regulated supply ? | Buhl | Pass Labs | 1 | 8th October 2003 10:51 PM |
| Page generated in 0.10931 seconds (81.51% PHP - 18.49% MySQL) with 11 queries |
