Keantoken's CFP cap multiplier - Page 11 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 21st November 2010, 09:42 AM   #101
stormsonic's Avatar
IMHO, negative version will perform much better, since base of Q4 is "feeded" through Q3. In positive version, base of Q2 is feeded through 100R resistor.
According to Walt Jung in Figure 1b, 40dB rejection is possible. No matter if anyone stack 2, 3,...10 transistors, if pass transistor's base is feeded with noise, you have "garbage in, garbage out" situation.
Swap R1 and Q1 positions.
Or feed base of Q1 through resistor, but then you need heavy R/C filtering, which will add complexity.
Or add JFET.
Or.....do anything.
But 100R resistor there is wery bad choice. No way to get better than -40dB (in theory).
Another important thing is capacitor. You want low leakage type there. Film caps are the best, low ESR solid-polymers (OSCON,....) are the worst.
Just my personal opinion.
Old 21st November 2010, 09:51 AM   #102
stormsonic's Avatar
Another example can be found HERE.
Old 21st November 2010, 06:08 PM   #103
I see nothing wrong with the operation of R1 Q1 as shown in Kean's schematic.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 21st November 2010, 06:28 PM   #104
keantoken's Avatar
Storm, the article doesn't say anything about my configuration, only stuff about opamps and zener diodes.
There is no difference between the positive and negative versions; the bases of the outputs are "fed" by the drivers, and the 100R resistors give ~6mA bias for the drivers, to reduce output impedance. There may be a difference if Early effect is different for PNP's and NPN's, but if so even Andy_C's models haven't revealed this.
Let me draw the schematic a different way.
- keantoken
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 21st November 2010, 06:51 PM   #105
keantoken's Avatar
Storm has a good point about low-leakage caps. Unfortunately the rubycon ZL datasheet is down, so I can't check.
Also, some models DO suggest that input rejection for the positive reg would be less because of the PNP transistor, by ~10db. SPICE has trouble modeling Early effect, so we can't know how drastic the changes are in real life.
- keantoken
Old 21st November 2010, 09:32 PM   #106
keantoken's Avatar
I take that back, the datasheet shows the 2SA1930 has worse Early behavior than the 2SC5171. This would forecast worse input rejection for the positive regulator.
- keantoken
Old 21st November 2010, 10:07 PM   #107
stormsonic's Avatar
Low current leakage lytic cap
Datasheet
Old 21st November 2010, 10:44 PM   #108
keantoken's Avatar
Storm, let's make sure we've got our facts straight before you write my name on anything of yours (awkward moment, lol). We only need low enough current to not turn on D7. Across 1k, this means less than 300uA. 300uA at 16V mean 53.3kohms. As long as the cap's leakage is say 80kohms, we're okay. What say you? I don't think ANY reasonable lytic will have such high leakage current.
- keantoken
Old 21st November 2010, 10:51 PM   #109
keantoken,
SPICE doesn't have any trouble modeling the Early Effect, but the transistor model may not have the correct parameter for Vaf.
Rick
Old 22nd November 2010, 12:35 AM   #110
Kean,
Can you also add some ESR and ESL into C1 in your simulation?
Bill
Vbe multiplier - bypass cap Donk Solid State 7 22nd January 2008 01:55 AM
Question(s) about CFP. Justcallmedad Solid State 94 20th September 2005 10:08 AM
cap multiplier or not? PederBass Solid State 13 23rd March 2004 06:26 PM
Cap. multiplier or regulated supply ? Buhl Pass Labs 1 8th October 2003 10:51 PM
Copyright Đ1999-2017 diyAudio
