Keantoken's CFP cap multiplier
Old 9th November 2017, 07:10 AM   #1071
keantoken is offline keantoken  United States
keantoken's Avatar
Interesting, the first thing I would do is check whether the input or output voltage is fluctuating by a large amount after turn-on. Also a basic health check makes sense just to see if it's still doing it's job.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 9th November 2017, 09:46 PM   #1072
alexkosha is offline alexkosha  United States
alexkosha's Avatar
No V fluctuations at input and output. V drop is 2.1v on 30V 100mA. Iím trying to measure it as I used to measure C Multiplier where I got 100mV at its input and 5mV in its output, but here is different.... My input and output is same low ripple. It is about 20mV with high frequency noise still added. Is it injecting back? Why Iím asking, just I know that my PSU is min 100mV ripple+noise.
Old 11th November 2017, 06:19 PM   #1073
alexkosha's Avatar
Maybe I'm doing something wrong with measurement setup?
Yellow trace in IN and blue is OUT. Files names are indication condition.
How to see if it is working ok?
Old 11th November 2017, 06:59 PM   #1074
keantoken's Avatar
So the input ripple should have been 100mV but is 12mV for some reason? There are some weird HF bursts on the waveform. The KM should be working better assuming the measurements are accurate.
Old 11th November 2017, 07:08 PM   #1075
alexkosha's Avatar
Yes, the input should be100mV from my switch PSU and buck convertor-controller. HF is due to scope probes GND, a assume. Will replace both transistors and try again tonight. It is 30V/90mA test.
Old 11th November 2017, 07:44 PM   #1076
keantoken's Avatar
I would look for the KM to be overloaded in this situation, since there is extra input ripple and the voltage drop seems more than it should be. The KM shouldn't have any influence over the input ripple, which is mainly determined by load current.
Old 11th November 2017, 07:52 PM   #1077
alexkosha's Avatar
What max Load to set for my test? I can run up to 30V 6A with my Switch PSU and LoadPro DC load module.
Old 11th November 2017, 11:56 PM   #1078
keantoken's Avatar
90mA is reasonable, I'm just suggesting your load current may be more than that for some reason.
Old 12th November 2017, 12:05 AM   #1079
alexkosha's Avatar
No. I monitored it with external DVM. It was same 90mA on load screen and DVM via 1R resistor.
Old 12th November 2017, 12:30 AM   #1080
keantoken's Avatar
What is the voltage across R1?
Keantoken's CFP cap multiplierHide this!Advertise here!
Vbe multiplier - bypass cap Donk Solid State 7 22nd January 2008 01:55 AM
Question(s) about CFP. Justcallmedad Solid State 94 20th September 2005 10:08 AM
cap multiplier or not? PederBass Solid State 13 23rd March 2004 06:26 PM
Cap. multiplier or regulated supply ? Buhl Pass Labs 1 8th October 2003 10:51 PM
