Lab Power Supply Design / Build
Old 3rd March 2011, 11:50 AM   #171
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
It is highly unlikely a 1uF cap will cause oscillation, when the 100uF cap (already in place) does not.
Like I said, the supply is stable now. Correcting the compensation through the feedback loop did it.
All of this, and other design specifics, were presented in detail earlier in the thread.
Old 5th March 2011, 12:11 PM   #172
keantoken is offline keantoken  United States
keantoken's Avatar
Film caps have MUCH lower ESR than electrolytics. Generally for electrolytics, the more F the lower ESR. The higher V the higher ESR. The larger size the lower ESR.
Having a very low ESR capacitor at the output has the effect of disconnecting the feedback loop because the output voltage no longer responds directly to a change in load or drive.
A 100uF lytic will generally have ESR>.1R. This is usually not lerge enough to goof up any regular. A film cap on the other hand has say ESR<.001R. This greatly increases the Q of any reactive network including this cap.
It doesn't sound as if you have actually tried testing the regulator with film caps. What puzzles me then is why you show a .3R resistor in series with C12. I could reason this is ESR, but I don't see it on any other cap, for instance the 100uF cap where it might be more important. If this was a film cap, then I can understand giving it ESR if it helps make the regulator stable. But if this cap needs ESR, then I don't suppose the regulator is stable into film caps.
- keantoken
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 5th March 2011, 01:05 PM   #173
MJL21193's Avatar
Kean,
Your first quoted statement above is incorrect.
It's plain on the schematic and the photos of the PCB that there is a film cap in place on the output - the 10nF (this, along with the 1uf in series with 300m ohm (revised to 4.7 ohms)) keep the output impedance low when the loop gain is falling off.
Would it bring you any satisfaction if I were to put a 1uF film cap across the output and photograph the results?
Old 5th March 2011, 01:22 PM   #174
MJL21193's Avatar
Here it is:
1uF cap across the output. Supply at 15VDC drawing ~1.3A:
Overall view, showing scope output:
Close up of scope:
No signs of instability. The regulator is still working extremely well to maintain voltage and kill ripple (as clearly seen in the scope shot).
I hope this answers some of your questions.
Old 5th March 2011, 01:33 PM   #175
keantoken's Avatar
My satisfaction is no prerequisite, I was only pointing out something you may want to consider and test. 10nF is not always large enough to cause oscillation. A test that would satisfy me is connecting a 1uF film cap between the terminals and testing with a square wave.
If my first statement is incorrect, I would like to know why.
I understand now that the 4.7R+1uF network is a zobel network. However if your intent is to keep output impedance reasonable at HF, hasn't the 100uF cap accomplished this? It should have lower impedance at HF than the 4.7R+1uF network. Is it possible that the increase from 300mR to 4.7R helped performance because it increased the total ESR at output?
EDIT: You posted before I did! Looks fine to me...
- keantoken
Old 5th March 2011, 02:02 PM   #176
MJL21193's Avatar
You mean the transient response test? That takes time to set up and I have other things to do at the moment. One of those is testing a new amp that is being powered by this supply. Pumping 10khz squarewaves through the amp near clipping has no effect whatsoever on the supply stability - that should be a reasonable test.
In all fairness and in the name of good scientific procedure, I disclose that the above scope shot was with the probe at 10x (not intentionally).
I redid the same load test, and here is the scope with the probe at 1x:
Still real clean with no discernible ripple or oscillation.
Lab Power Supply Design / BuildHide this!Advertise here!
Want to build a Pass lab design....help desired jmillerdoc Pass Labs 25 22nd August 2010 11:58 AM
Lab Power Supply Nikon1975 Equipment & Tools 2 11th December 2009 10:52 AM
Regulated Lab DC power supply Sir Trefor Tubes / Valves 6 28th July 2007 06:13 PM
diy dual lab power supply morpheus82 Power Supplies 25 10th July 2006 12:41 AM
Lab Power Supply Current Limiting Q Wynand Equipment & Tools 4 27th September 2005 10:44 PM
