Go Back   Home > Forums > Amplifiers > Power Supplies
Old 16th December 2010, 10:29 AM   #151
MJL21193's Avatar
Originally Posted by AndrewT View Post
The coarse could be switched rather than continuous.
Ah, a DPDT switch to put a 10K resistor in series with the pot, either before for 'high' adjust and after for 'low' adjust.
I think I like the fine adjust pot idea better. A 1K pot will vary the voltage by about 2V over its range which would be perfect. I can get a smaller pot in the cow catcher no problem. The only obstacle is that I don't have any more 1K pots. On my next Digikey order, I get a pair and at that time I'll wire them in.
Snow is a-coming down here and it's a grand day to put some off the finishing touches on this project. Time to get it off the bench and into active duty.
Old 16th December 2010, 10:46 AM   #152
I was thinking more like switch positions for 0-5Vdc, 5-10V, 10-15, 15-20, 20-25, 25-30. Would suit a 6way rotary. Then continuous fine to cover the spread of 5V at each position.
Old 16th December 2010, 11:56 AM   #153
MJL21193's Avatar
That is probably more practical for a bigger unit. The 2 pot solution will give the resolution I'd like but still make for quick adjustment. To see the accuracy of the fine adjust pot, I'd have to connect a multimeter - my analog meters will not show it precisely enough. I may, at some time in the future, change the scale on the voltage meters from 75VDC to ~37VDC for better precision.
I like multi position switches but only if they are board mounted, otherwise there are too many wires running willy nilly. There is enough of that going on now.
Old 16th December 2010, 01:52 PM   #154
MJL21193's Avatar
Some additions that should have been on the PCB - resistors in series with the voltage control pots and current limit pots. I put these in place on the pots:
The 'light tube' that channels the light from the bulb limiter out to the front panel:
just a piece of 1/4" plastic tubing.
Old 16th December 2010, 02:53 PM   #155
MJL21193's Avatar
A look under the hood:
Everything in place, neat and tidy.
In place in the gear and parts hutch:
Ready for action.
A close-up of the bezel I added to the front panel:
I just roughly laid out and hand printed (in pencil) the scale for the current limit.
It is done(!!) for now.
Final specs are ~0 to 35VDC at a maximum 2.2A.
A lot of fun to build, a great learning process and it looks to be a very useful tool indeed. I'm sure I'll put it to good use in many future projects.
Old 16th December 2010, 03:22 PM   #156
MJL21193's Avatar
Final schematic:
Old 17th December 2010, 12:21 PM   #157
akis is offline akis  United Kingdom
I'm running it on the trial version of 11 and it isn't stable. It is running very slowly as well (a bad sign in my experience) with it taking taking 20-30 seconds to step thru .5 seconds of operation.
After I loaded it, I had to change the 2N5459 to 2SK170 (no MS model for that) and I ran it. It started to oscillate at .443 seconds and then halted at a convergence error. Maybe something was corrupted while zipping it.
This is not an overly complex circuit and that is not typical performance for MS.
Tit for tat, I'll attach mine and you can check out its performance. Give it about 20 seconds (MS timestep clock) for it to settle in. Adjust R18 for 10VDC after the LM317 and R19 for ~1.3VDC at the anode of D9.
Attachment 200413
Sorry I was out of London for a week. I am back and will try it out tomorrow-ish.
Old 22nd December 2010, 02:28 AM   #158
MJL21193's Avatar
Hey akis,
Did you get any further with your design?
Old 24th December 2010, 07:19 AM   #159
jaycee is offline jaycee  United Kingdom
This thread caught my attention - been wanting to do a bench supply for a while! I had more or less set myself on a discrete copy of the MC1466L with some adjustments until I looked at this.
I simulated it in LTSpice and spotted a problem. I set the output voltage for 12V (or near as possible) off load. Then I added a resistor that drew 1A. The output voltage *rose* to 12.2V. Seems a bit odd.
This circuit does have one neat advantage over the 1466L, no need for a separate floating supply. OK small transformers are cheap, but it's still a pain. However the 1466L does use high side sensing, which means it'll pick up any short, not just a short to ground.
Old 24th December 2010, 01:02 PM   #160
MJL21193's Avatar
Hi jaycee,
What can I say about simulation? I use it extensively myself.
I can say that the circuit does not behave that way in Multisim and, more importantly, it does not do that in reality. The addition of a 1A load causes less than 10mV deviation in the supply voltage at 12VDC.
You might want to check the ground references for your measurements to ensure they are on the regulated side of the current sense resistor (0 volt side). This tripped me up a few times in the beginning.
I like to be efficient and run everything from one transformer. Less mains voltage wires to run, less space taken up inside the case. The implementation in this supply is in no way inferior to a separate supply and the results speak for themselves.
Not sure what you mean by 'any short, not just a short to ground'. The supply limits current on a dead short between the positive volts terminal to the 0 volts terminal to less than 2.2A. Here that is in action:
That is a 1/4 watt, 0 ohm resistor across the terminals. It looks odd but demonstrates the effectiveness of the current limit and the foldback feature.
This was actually me testing some of the new cheap resistors I bought (5000 - E12 series from 0 to 10M ohms for $20) to see how much actual current they could withstand before failing. The 0 ohm resistor didn't fail, since its wattage wasn't exceeded, despite the ~2.1A current draw (near 0 volts).
Want to build a Pass lab design....help desired jmillerdoc Pass Labs 25 22nd August 2010 11:58 AM
Lab Power Supply Nikon1975 Tubes / Valves 2 11th December 2009 10:52 AM
Regulated Lab DC power supply Sir Trefor Tubes / Valves 6 28th July 2007 06:13 PM
diy dual lab power supply morpheus82 Power Supplies 25 10th July 2006 12:41 AM
Lab Power Supply Current Limiting Q Wynand Equipment & Tools 4 27th September 2005 10:44 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
