current limiting for power supply - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 9th November 2010, 04:06 AM   #11
What are the specifications ? pls provide following details.
1) Regulated variable voltage min - max.
2) Are you looking for continues variable current or stepped current limiting as your previous?
some regulator ICs has this built in feature. so we don't reinvent the wheel. Put your needs in detail. so a circuit can be provided to you.
just found one that might be of help to you check the link Powersupply design
There is always a first time....
Old 9th November 2010, 08:38 AM   #12
jitter is offline jitter  Netherlands
jitter's Avatar
If 2.85V min. output is acceptable, I would suggest you have a look at the L200 adjustable voltage and current regulator. Basically it's an adjustable VR with adjustable current limit. As-is, it's max. Io is 2A, but can be extended beyond that with an extra transistor (see application notes in the datasheet).
Old 9th November 2010, 09:54 AM   #13
akis is offline akis  United Kingdom
As I said in the beginning I am trying to replace my age-old PSU which I am very fond off. It sits on the left of the oscilloscope in this old picture I just found on these forums.
It is very old, the rotary switches are huge and made to withstand a nuclear explosion, the on-off switches are also big, and the down position is ON!
It is dual independent channel from 0 to 30 V in steps of 100mV and current limiting as 50mA, 100mA, 250mA, 500mA, 1A and 2 A.
The output voltage selection is effected by 3 rotary switches: 0-10-20 V, then 0, 1, 2, 3 ... 9 V, then 0.1, 0.2, 0.3 ... 0.9 V.
For current limiting again there is a beefy rotary switch that pre-selects the desired value.
I quite like the way you can select the current limit accurately without actually having to reach it, and I also like the way you can select the voltage output just from the switches.
For my project I will use a rotary pot to adjust the voltage, but will use a rotary switch for the current limit with preset limit values.
Reading above and in general I have learned to watch out for many things:
1 what happens when you power up, do you get spikes at the output ?
2 what happens when you power down?
3 what happens when you short the output (big output caps) ?
4 how much voltage drop do you get as the current increases / how stable is the output voltage
5 how much ripple when current increases
6 how good is the current limiting action
7 how stable is the output voltage wrt temperature changes (zener operating in 0 temp. coefficient mode???)
8 can you cascade two channels to make a dual rail supply, and can you then additionally ground the "0" terminal ?
9 how hot does it get and does it need a fan to cool the pass transitor (and how noisy will it be then)
10 do we need a slow start circuit (already got that one made if needed)
Old 9th November 2010, 12:47 PM   #14
macboy is offline macboy  Canada
Originally Posted by cliffforrest View Post
I would beg to differ! This is precisely what comparators are FOR; never being operated in linear mode.
Hysteresis from +ve feedback is the usual remedy, and, as I suggested earlier, check out fold-back limiting which has its own useful characteristics.
Yes, comparators are designed to not operate in linear mode. So, if what the original poster wanted was a hard cut-off (current limit reached = disable output) then maybe it would work. But that's not what he wants. A traditional "current limiter" is actually a current regulator, and must operate in linear mode. No comparators need apply.
Old 9th November 2010, 01:04 PM   #15
I'd suggest finding the service manuals for some good quality bench supplies and looking at the circuit diagrams therein. Agilent, for example, makes (and has made) many nice supplies and all the service manuals are freely available on their website. The circuits can usually be easily be adapted to different voltages and/or currents, by changing just a couple resistors to set the new upper limits for current and voltage ranges. Try finding a model simiilar in specs to what you want then look at the service manual.
Old 9th November 2010, 03:08 PM   #16
A hard cut off is something I have considered : you exceed the limit, power supply switches off, you have to press "reset" to get back up again, like a fuse.
For softer limit I will try to put some negative feedback today, so the op-amp will work like an amp and not like a comparator, maybe this will avoid the oscillations. I also do hope the simulation software is true
Old 9th November 2010, 03:45 PM   #17
the comparator allows the sharp transition. When it triggers it should bring in the current limit, not switch the current to zero. Let's say the current is 99mA, then due to temperature effect the test circuit starts to draw extra current, maybe passing through 100mA to 101mA.
The comparator could see the excess above 100.01mA and limit the output to pretty near exactly 100mA. With hysteresis added the limiter will not come out of limiting at 100.0mA but at some lower current of say 99.99mA or 99mA or 91mA. You design the hysteresis to suit what you want the limiter to protect against.
An alternative is to have two different regulators in series. That was my earlier suggestion and probably the simpler to construct.
Put a current regulator in the line between the supply and the voltage regulator.
While the voltage regulator maintains set voltage at a current less than the set limit, the current regulator is wide open and passes current with virtually no Vdrop. As current hits the set limit, the current regulator takes over and starts regulating, i.e. increases the Vdrop to achieve the current limit.
The voltage regulator now has insufficient input voltage to allow it to work as a regulator and falls to wide open. The net result is that you have a fixed voltage below and at set limit and a lower output voltage when the current regulator is active. I strongly suspect your PSU has been assembled this way.
The knob settings are feeding the correct feedback ratios to the two different regulators so that normally the voltage regulator is doing all the work.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 9th November 2010, 05:18 PM   #18
MJL21193's Avatar
Hi akis,
How about circuit breakers? Size according to your transformer, giving a bit for a safety margin.
Adding complexity and cost, you could have 2 pairs of breakers, one pair for high current and the other for low and switch between these.
Dead easy, cheap(ish) and when mounted on the front panel, convenient.
Old 9th November 2010, 06:04 PM   #19
It's quite obvious that you've never actually designed a current limiter. Your thought experiment above is interesting but impractical.
Replace "current" and "mA" above with "voltage" and "V" and see if your explanation makes sense for a voltage regulator. I thought not. I'll state it again: a current limiter is a current regulator. You don't just turn it on, and magically the current is limited to a pre-defined value. What happens when the load changes? How does your described current limiter keep the current constant at 100 mA? Current limiting is a dynamic linear process just like voltage regulation. Hysteresis is neither needed nor desired in a current limiter. Oscillations or instability of the control loop are no more (or less) of an issue than in any voltage regulator.
Old 9th November 2010, 06:09 PM   #20
I cannot get the limiter to work smoothly using op-amp withnegative or positive feedback. It seems to want to drive the output voltage really low (as the action is to short the voltage reference) and then it picks up again etc.
So I tried your other suggestion, a PNP transistor acting as a constant current source before the voltage regulator, and this so far seems to work very well, no oscillations, it just lets the current rise until it hits a limit and then lowers the voltage.
The problem with this approach seems to be the voltage sacrifice we want to make at the current limit level. With the current monitor approach we would drop, say 100mV across the sense resistor. With the constant current source I am not sure how many mV to drop across the emitter resistor. We know the base-emitter junction is 0.6V, and intuition tells me that we'd need a multiple of that to have a stable performance. Currently I am dropping approximately 1.25V across the resistor - not sure if that is enough, or if we can get away with much less.
Help with current limiting device Rob11966 Power Supplies 2 23rd November 2009 06:47 PM
LM338 Current Limiting imix500 Parts 48 22nd October 2009 11:21 AM
Does any power amp have a current limiting device? beppe61 Solid State 44 22nd December 2005 11:47 PM
Lab Power Supply Current Limiting Q Wynand Equipment & Tools 4 27th September 2005 10:44 PM
Load Current limiting k1jroth Solid State 2 20th November 2004 06:20 AM
Copyright 1999-2017 diyAudio
