hi there,
i've got a problem with an amp here that i can't figure out how to fix.. i've changed every single part (except the NJM2068, which i replaced with other opamps like the TL072 or 4558D), and i can't get the problem to disappear. the problem is hum on the 220VDC output.. which is very audible through the tubes it feeds. the whole circuit starts to oscillate. -15VDC is stable, 10UF is also new.. the circuit did work for 15 years and i thought the 10UF or the opamp would do the job, but no.. anybody have any ideas? |
#2 |
are you powering amp directly from 220V city electricity?
#3 |
sorry, i forgot to check this mail account! thanks for the question!
the input is from the transformer, not directly from the wall. i built a conventional power supply with a 3k9 Resistor after the 10UF and a second cap 33UF, but taking the ground from the power supply i get a ground loop hum. not nearly as bad as the hum from the voltage regulator, but audible. |
| Split Voltage Switching Power Supply for Power Amp | vectorplane | Swap Meet | 2 | 23rd April 2011 11:48 PM |
| tube power supply voltage | ohill | Tubes / Valves | 5 | 27th April 2010 04:46 PM |
| SE Tube Preamp circuit using 6922/6dj8 at low voltage(24volt) needed! anyone? | tone | Tubes / Valves | 7 | 20th February 2010 12:11 AM |
| Help needed - Connecting Aux Voltage (HG Supply) to UCD400AD Ver 6.1þ | taykg | Class D | 0 | 2nd June 2009 02:02 PM |
| Imphy high voltage tube supply transformers | jean-paul | Swap Meet | 0 | 24th August 2006 06:44 PM |
| Page generated in 0.06444 seconds (79.54% PHP - 20.46% MySQL) with 11 queries |
