Go Back   Home > Forums > Amplifiers > Power Supplies
Old 4th November 2010, 06:16 PM   #1
vasko is offline vasko  Czech Republic
Default Electronic fuse
I need electronic scheme of the current limitation circuit on the scope of 20 mA to 2A, working voltage up to 30V DC
circuit should have little resistance, because after him I'd put LM317 to adjust voltage from 0-30V
little about the circuit:
need to have 2 states:
1st state - conducting - green LED glows
2nd state - not conducting - red LED glows
when the current reaches max value it should remove current completely and not to hold a limited supply, like real fuse
of course, point to expulsion can be adjusted by potentiometer
does someone has such a scheme?
Old 4th November 2010, 07:09 PM   #2
Banned
Resettable polyfuse:
http://www.littelfuse.com/data/en/Da..._PTC_2016L.pdf
You can't adjust the value, but you can get different values, so you could switch different ones into the circuit.
google 'resettable polyfuse'
w
Old 4th November 2010, 07:39 PM   #3
thank you wakibaki but i'd like to build one my own with power tranasistor (bipolar or mosfet),two LEDs and potentiometer and reset switch
does some one has such schematic?
Old 4th November 2010, 08:55 PM   #4
tomchr is online now tomchr  United States
tomchr's Avatar
Sounds like you're building a lab supply. How about using an LM723 instead? It has provisions for both current limit and voltage regulation built in. Add a power device like the ancient 2N3055 (or something newer) and you're in business.
~Tom
Old 4th November 2010, 09:04 PM   #5
Did it Himself
richie00boy's Avatar
Google foldback current limiting.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 4th November 2010, 09:52 PM   #6
yes,you can call it lab supply
i looked at LM723 data sheet,if I got correctly current is just limited at some value
what I need is current turned down completely and red LED turned on in case of reaching max value
richie im googling this right now
Old 4th November 2010, 10:10 PM   #7
i guess i need voltage comparator and flip flop or at least IC that has those
here (LM723) i see just one potentiometer,i need one for voltage and second for current and reset switch
this looks too basic...
Old 4th November 2010, 10:22 PM   #8
Banned
Something like this?
w
Old 4th November 2010, 10:28 PM   #9
I definitely want to use transistor(mosfet(for less resistance),but bipolar is ok too), no relay.
Old 4th November 2010, 11:52 PM   #10
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
I wrote this a bunch of years ago:
Downside is the shunt resistor voltage drop. To minimize that, and eliminate the Vbe tempco, you'll need a voltage reference (e.g. TL431, or whatever your reg has), voltage divider and comparator. You can use the flip-flop as shown, or something else. An LM393 could be used, using the other half as a flip-flop (lots of hysteresis).
The circuit looks worse if you need high-side switching instead.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Fuse housing melting but fuse not blowing, ppi amp rawadia Car Audio 21 2nd August 2008 10:39 AM
What fuse do I need? ifrythings Power Supplies 14 25th April 2008 08:53 AM
Why main fuse and not rail fuse? digital desire Solid State 10 3rd December 2006 08:07 PM
amp rating for fuse and fuse holder? riotubes Parts 5 27th August 2006 03:10 AM
Page generated in 0.09835 seconds (79.87% PHP - 20.13% MySQL) with 11 queries
