Xentek 5kva isolation transformer runs hot! - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 13th October 2010, 02:07 AM   #11
That is one big transformer! I can't imagine why you'd want to use such a thing.
If it runs hot it must have a shorted turn. If you have a wattmeter, measure the power draw with no load. Obviously it's high or you wouldn't have that much heat.
I submit that the thing is defective.
Old 13th October 2010, 02:12 AM   #12
AndrewT, looking for a compendium of troubleshooting tidbits - well just ask me. I have more information in my head than even I can believe. Seriously, these things require a certain talent to invent. For instance, I invented (I am sure I'm not the first) a method of discovering where a break is in a shielded cable. It's usually at one end but my method finds it without cutting or piercing, within an inch or so.
It also helps that I have a degree in Electrical Engineering, have been a radio amateur for over 60 years, and owned an electronics repair shop for many years.
Old 13th October 2010, 10:44 AM   #13
how about writing a transformer Wiki?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 13th October 2010, 12:44 PM   #14
AJT is offline AJT  Philippines
AJT's Avatar
to dramatically reduce the core loss connect the transformer as 240v to 240v and use on 120v.
this makes a lot of sense if you are not using the full 5kva rating of your isolation traffo..
Do not despair, though they seem to be winning
now, they always fall in the end......Gandhi
Old 16th October 2010, 02:22 AM   #15
is your line 120 or is it 125?
dropping the line 10% will drastically cut core losses.
Old 20th October 2010, 04:28 AM   #16
ktuuri is offline ktuuri  Canada
Yes, it will run cooler and may benifit your system having your amp on Balaned power.
Dynaco ST-120 runs hot bobgroger Solid State 6 15th April 2008 06:20 AM
OPA4228 runs hot iron25 Solid State 2 1st July 2007 06:42 PM
Topaz 5kVA Isolation Transformer ampsarus Swap Meet 1 7th November 2005 08:00 AM
power acoustik one channel runs hot montecarlossfan Car Audio 7 21st June 2005 02:10 AM
BOSOZ's PSU runs very very hot ruangrit Pass Labs 18 6th February 2003 12:45 AM
Copyright 1999-2017 diyAudio
