Need to knock a few volts off..!
Old 22nd September 2010, 04:49 PM   #11
Ar4 is offline Ar4  Latvia
OK, thanks Mooly. This one looks quite simple, unlike other circuits I've found.
Old 22nd September 2010, 04:52 PM   #12
Mooly's Avatar
It's an easy amp to build... I'm sure you'll be pleased with it.
Old 23rd September 2010, 06:40 PM   #13
johnalexwarren is offline johnalexwarren  England
I hope so - can't wait to hear it :O)
Old 24th September 2010, 04:54 PM   #14
macboy is offline macboy  Canada
Originally Posted by Mooly View Post
Macboys suggestion of a capacitance multiplier is interesting, and while achieving the reduction in voltage as far as the amp goes, it still needs the main reservoir caps to withstand the full output from the tranny. The heat "saved" from the outputs by the lower rail is still produced by the pass transistors in the multiplier.
Yes, a capacitor multiplier doesn't eliminate the need for sufficient reservoir caps. It does however reduce ripple by a significant factor. That is where the name comes from; the ripple voltage on the output is equivalent to using much large reservoir capacitors.
Good point about the heat too. You don't reduce heat overall, but you distribute the heat between the cap.mult. transistors and the amp output transistors. And you put the amp's output transistors into a safer operating point (VCE * IC), so that in theory you can pull more current through them without damage.
Need to knock a few volts off..!Hide this!Advertise here!
knock off Belle Klipsch? capt mike Multi-Way 18 21st March 2016 01:44 PM
power transformers 220 volts to 110 volts garydmd Chip Amps 3 7th April 2007 02:52 PM
Infinity Beta Knock off Mats J Multi-Way 8 7th December 2006 06:36 PM
Gainclone is on 120 volts will it be fine at 220 volts? Jimmy154 Chip Amps 7 29th June 2005 12:10 AM
