how do i convert 220VAC to 220VDC? - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 30th September 2010, 05:56 AM   #21
kavermei's Avatar
Send a message via MSN to kavermei
Originally Posted by metalsculptor View Post
Output voltage is mainly dependent on rate of fall of the primary current as per v = LdI/dT
Uhm, not quite. DC output voltage is dependent on input voltage, turns ratio, and duty cycle.
Never send a human to do a machine's job. --Agent Smith
Old 30th September 2010, 06:06 AM   #22
On a forward converter yes but on a flyback converter no the forward conversion voltage is blocked by the flyback diode and only the voltage from the collapse of the magnetic field is used.
Old 30th September 2010, 07:19 AM   #23
Edit to my last comment, I assumed that the original circuit was flyback because an EHT transformer (television) was mentioned and traditionally there are operated in flyback mode. With switching transistors and cheap components there is no reason to run the EHT transformer in flyback mode like was the norm in valve days.
Old 30th September 2010, 01:39 PM   #24
star882 is offline star882  United States
star882's Avatar
You'll need to take apart the core and remove the gap if you want to run it in forward mode.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 1st October 2010, 07:48 AM   #25
coolfox is offline coolfox  Europe
guys ..i succeeded and this message isn't posting from heaven there was an current limiting problem with the regulator unit and i fixed it.and also i used a better trigger circuit withstanding high voltages..
Smps 220vac / 13.8vcc For 100a albert_emule Power Supplies 13 14th July 2009 01:17 AM
220VAC to 12VDC conversion ioanno Class D 1 21st December 2004 12:24 PM
Plus biasing heater (220vdc above ground) Bas Horneman Tubes / Valves 7 24th February 2003 02:32 PM
I Have a big problam !!......with Inverter 12VDC to 220VAC Dj BASS AMP Solid State 27 23rd August 2002 09:14 AM
Copyright 1999-2017 diyAudio
