Hi All
I have this simple soft start scheme which I modify to include a LED. My question is the resistor 220R sufficient for the LED? Thanks |
#2 |
This is the original scheme.
#3 |
If the power supply is putting out 9.1 volts, the resistor value is a bit low.
A resistor in the range of 820 ohms to 1k ohms would probably be better.
Frank |
#4 |
Hi Frank
Thanks for helping. The soft start is for a500Va transformer. The main supply is from 220v. I have remove the zener and replace with only a 20k resistor. Will this work? Thanks again. |
#5 |
Measure the voltage of the power supply before you install the LED.
Make sure that the relay coil is in the circuit or the voltage will be very high. What is the d.c. resistance and operating voltage of the relay coil? That will determine the resistance of R1 and R2. I'm guessing that 20k is too much resistance for the LED.
Frank |
#6 |
Hi Frank
Below is the spec: R1, R2*.............................470K 0.25W 1% mf R3*..................................220R 0.25W 1% mf R4, R5, R6, R7...................10R 5W C1...................................330n 250V (for direct mains connection) C2, C3............................. 470uF 40V B1.................................. B250C1500 Re1.................................24V (250V-8A contact) F1*..................................2A slow blow |
#7 |
I've simulated the circuit. Depending on the relay coil resistance, you may need to trim R1 and/or R2 to obtain something near 24 volts on the relay coil.
The resistor feeding the LED should be about 1.2k/1.5k. A .25 or .5 watt resistor is good.
Frank |
#8 |
Hi Frank
Thanks again. I'll change it to 1.5k 5w. What value is suitable for R1 and R2? The mains is at between 220-230v. I have connect a voltage regulator which will output at close to 240v to the soft start. Last edited by pmchoong; 12th September 2010 at 03:28 PM. |
#9 |
Don't need a 5 watt resistor. .5 (1/2) watt is big enough.
The value of R1 and R2 depends on the coil resistance of the relay. Increasing the value of C1 will also increase the voltage to the relay coil. Experiment with the values to obtain something near 24 volts on the relay coil.
Frank |
#10 |
Hi Frank.
Thanks for your time and advice. I appreciate your help. Will try other value with R1/R2 to obtain 24v. |
| Soft Start Necessary? | dtaylo3 | Class D | 2 | 26th December 2008 09:05 AM |
| B+ soft start | Gluca | Tubes / Valves | 2 | 3rd September 2007 01:04 PM |
| Need a soft start? | maxpou | Solid State | 19 | 18th April 2007 09:23 PM |
| Soft start & Soft Switch circuit: can anybody help? | m.parigi | Solid State | 95 | 22nd August 2005 03:32 PM |
| Page generated in 0.10306 seconds (76.12% PHP - 23.88% MySQL) with 11 queries |
