#11 |
nightanole -
I assume you haven't physically wired it as you show where +ve and -ve supplies are shorted to GND or you're going to get a loud bang as your caps explode. Assuming that's not the case, why have you linked +PGND to the -ve supply and -PGND to the +ve supply and not the other way around? Am I missing something here? Last edited by Gopher; 8th September 2010 at 05:46 PM. |
#12 |
Try this thought. The top powersupply is a carbon copy of the bottom power supply. so the top of each power supply is positive, and the bottom of each power supply is negative. Series them together and you get 60 volts with a center tap. Connect the tops to the tops, and the bottoms to the bottoms, and you get parallel arrangement.
There really isnt a negative rail like with a regulated setup, its really just 2 30volt powersupplies thanks to the fact the center rail isnt connected on the pcb. If you go back further you will see im really just connecting the positive posts of the caps together, and the negative posts together. |
| Dual supply for LM1875 split supply | dovganj | Power Supplies | 30 | 6th November 2009 03:19 AM |
| power supply for 41hz amp6 basic | bull041161 | Class D | 3 | 27th April 2009 09:44 PM |
| help powering 41hz amp3 and an active crossover on the same supply | Nemophyle | Class D | 12 | 28th February 2007 08:59 PM |
| Dual lm3886 pcb | wunbin47 | Chip Amps | 1 | 17th May 2005 09:50 PM |
| Dual CT Transformers with LM3886? | blip | Chip Amps | 28 | 15th April 2005 05:55 AM |
